Car Idle's Ok, but car has heavy bog!
My car was turbo'd before, and I just recently put eveything back into stock. Everything is stock except my JE 9:1 pistons and eagle rods. As everything else is stock, along with some advance timing adjustment, the car idle's "somewhat" ok. If I apply some throttle, the car has "HEAVY" bog. I get complete bog as soon as I apply a bit of throttle. There are no check engine lights, which seems a bit odd. Also, my fuel pressure gauge reads at 40.
Can I get some help please! Modified by PolySquared at 5:40 PM 6/25/2004 |
Re: Car Idle's Ok, but car has heavy bog! (PolySquared)
test your tps and map...
Re: Car Idle's Ok, but car has heavy bog! (taz77)
well, I already try adjusting the TBC and the timing. Its really weird! I can't get a code either!
Try checking your O2 sensor... clean it.
did u check ur tps?
how's your cam and ignition timing?
Re: Car Idle's Ok, but car has heavy bog! (mmuller)
did you have your timing belt off? maybe you got it off a tooth . that would explain the problem . even if you did not have it off i would still check it.
it sure sounds like you have your tps plug and map plug switched
Re: (KMaxwell)
I'm new with the term "tps", but I'll work on that. Yes, my timing belt was off and I slapped that back on.
Re: (PolySquared)
That happened to me the other day and it turned out to be one of my sparkplugs, was bad. Fuck Bosch Platinum |
Re: (PolySquared)
TPS = throttle position sensor.
