Momo hub stuck on steering column - how to get off?
In the process of taking my momo hub off to put my stock wheel/airbag back on for the CA ref on Monday but of course, problems.
The hub is stuck on the steering column, it won't budge...I have taken the 18mm bolt off and figured that it should just pull up and off but it won't move.
Any ideas? Should I try to pry the damn thing off?
Thanks
Thanks
You can get a steering wheel exctractor to get it off its the easiest way. I believe they are not that expensive. You can also pry it out, I have done it, but you have to be extremly careful. You do not need to use force, but just wiggly it of. However, for it to come out it has to come out straight. It will take a while before it breaks loose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamsol »</TD></TR><TR><TD CLASS="quote">cant you rent that stuff at autozone for free?</TD></TR></TABLE>
Yes, as long as they have one, and they usually do.
Sijray21
Feb 28, 2006 08:33 AM
GusRock77
Honda S2000
Mar 2, 2005 07:15 AM
