install a/c into the EK civic
Hi guys,
Under very fortunate circumstances, I have a complete a/c system from a DC2 integra.
Does anyone know if it is hard to install that into my 96 EK hatch? Lots of modification needed?
thanks very much in advance!
Re: install a/c into the EK civic (energie)
dc2 a/c assembly is different then civic in many ways.
the condensor first of all in a dc2 is a sequential setup with the radiator. in a civic however, if you have ac, the condensor and radiator are run parallel to each other. thus, the condensor will not fit, go and take a look. only way that condensor will fit is if you have the integra radiator, and you drill out the radiator and ac mounts and modify/weld them back on.
obviously, the ac lines are going to route differently as a result also.
compressor isn't going to fit on your current bracket either, unless you have a swap, but if you did you wouldn't be asking this question because you'd know the answer.
to put it simply, probably better off getting the civic ac system.
ac, air, bracket, civic, conditioning, ek, hatch, honda, install, installation, installing, lines, setup
