ITR clutch/flywheel assembly fit on an LS block?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 »</TD></TR><TR><TD CLASS="quote">Thanks
what about a type R oil and water pump?</TD></TR></TABLE>
Keys to making a strong LSvtec, that will last
If I use the ITR crank with ITR pistons and rods, I will improve my r/s ratio but lose the LS torque. But what about the compression? will it be close to stock ITR compression?
owen, there is no need to drill a hole in the back of the block to use the oil cooler, but you will need to swap out the ITR/GSR coolant neck on the back of the block for the ls one. ITR clutch and pressure plate will work on an LS block, just no ITR cluch with an LS flywheel or vice versa. ITR oil pump and water pump will work as long as you use a Vtec timing belt.
With an LS block with the ITR crank and rods with stock pistons you will only have a 9.3 CR. You will maintain the revabilty of an ITR but i doubt it will be as reliable, it will not have the oil squirters. I would swap on the ITR girdle,windage tray, pick up, and oil pan. Personally, id swap all the itr stuff into a bare ls block with some b16 pistons or ctr pistons..
b16 pistons in ls block with ITR head : CR = 11.11:1
b16b pistons in ls block with itr head : CR = 11.75:1
goodluck with the exp0
Rex89
Jun 27, 2007 12:37 PM
lsvtec101
15
Mar 29, 2004 12:05 PM
