IACV Question?
Old Jun 25, 2004 | 04:13 AM
whoobeedoobee's Avatar
Default IACV Question?
My idle falls pretty low and nearly stalls when my A/C is on. I read that the most likely cause is a dirty IACV. So, I unbolted it from the intake (but did not unhook coolant lines on bottom) and sprayed carb clearner into the screen. Now the idle problem is worse and my car stalls while idling and when the A/C is on.
Is it neccessary to completely remove the IACV?
or could my problem be something different?
Old Jun 25, 2004 | 04:28 AM
monicle's Avatar
Default Re: IACV Question? (whoobeedoobee)
you should probably go through the steps to correctly reset the Idle. I was having similar trouble and it was my idle speed.
Old Jun 25, 2004 | 04:45 AM
Default Re: IACV Question? (monicle)
Do you have more info on resetting the idle? or do you mean adjusting the idle screw?
Old Jun 25, 2004 | 06:24 AM
monicle's Avatar
Ill get the steps from the helms at lunch and post them for you. theres more to it then just adjusting youre idle screw.
Old Jun 25, 2004 | 06:39 AM
Jokerluv's Avatar
also try resetting the ecu
RinzEG6
Nov 24, 2014 12:02 PM
dc4b20
22
Dec 3, 2012 09:54 PM
Tyrant_007
Mar 28, 2011 08:01 PM
DC2*Integra
Sep 20, 2005 12:51 PM
