LsVtec B18c5 head?
Old Jun 24, 2004 | 07:06 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default LsVtec B18c5 head?
Hey im going back and fore i was thinking about b18c5 in a ls 90-93 yet but i need 92-93 for b18c5 but can i do ls vtec with a c5 head or defines the whole point of the ls vtec?thanks in adavance
Gsr head is what b?
Modified by CrxStreetRacer at 8:20 PM 6/24/2004
Old Jun 24, 2004 | 08:34 PM
JDMotive's Avatar
Default Re: LsVtec B18c5 head? (CrxStreetRacer)
Your post is a little hard to understand but ill try to help.You can use a type r head on an ls/vtec.Why would you need a 92-93 to use a type r head?The gsr is a b18c1.An ls vtec is any integra LS block from any 90-2001 non vtec integra with any dohc vtec b series head(b16a,b18c etc)
Old Jun 24, 2004 | 09:26 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: LsVtec B18c5 head? (JDMotive)
oh sry you cant understand me but i can use an itr head on a b18b1 block?
Old Jun 24, 2004 | 09:40 PM
FastAllmotorLsVtec
Guest
Posts: n/a
bump for the nite!
Old Jun 24, 2004 | 09:56 PM
Sack Master's Avatar
Do you know whats involved in doing an lsvtec? It's not just bolting a vtec head to a non-vtec block. Just understand that. Yes an ITR head will work.
Old Jun 24, 2004 | 10:04 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: LsVtec B18c5 head? (Sack Master)
ya i know their all kinds of stuff line fittings gaskets ya the whole nine yards
Old Jun 24, 2004 | 11:08 PM
JDMotive's Avatar
You will need a T fitting in place of the oil pressure sensor,the oil pressure sensor should screw into the end of the T.Than you need to run an oil feed line to the head.The line should be braided and i suggest -6an.There are other fittings/adaptors you need to get for the oil line to screw into the T and to screw into the head,but i do not remember the exact size,as i have all of that written down at the shop.You will also need to tap the original vtec oil supply hole on the bottom of the head,than screw a plug into that also.You will also need to relocate the dowel pins on the underside of the vtec head to the other side of the head.This only involves enlarging holes on the opposite side of the head to accept the dowels.
Old Jun 25, 2004 | 08:56 PM
FastAllmotorLsVtec
Guest
Posts: n/a
can u use an b16b i just thought about it?
Old Jun 25, 2004 | 09:24 PM
DEVIOUS_EG*'s Avatar
Old Jun 25, 2004 | 09:55 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: LsVtec B18c5 head? (DEVIOUS_EF*)
damn cant you alteast say sumthing than dam face that means jack!
Old Jun 25, 2004 | 11:12 PM
Combustion Contraption's Avatar
yea, you COULD....
research more first please.
Old Jun 26, 2004 | 12:18 AM
Malgerus's Avatar
Default Re: (LsVtec92Hatch)
Any B series VTEC head will work. By the way, B18C5, B17A, B16A (and maybe B, not sure) heads are the same casting (PR3).
Old Jun 26, 2004 | 09:01 AM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: (Mr. S)
thanks
Old Jun 26, 2004 | 09:53 AM
ragerized's Avatar
Default Re: (CrxStreetRacer)
i would also recommend a vtec oil/water pump.
ThatDb8guy
19
Jul 2, 2014 07:01 PM
chris1405
Dec 27, 2012 08:06 AM
pakn-heat
Dec 1, 2009 04:17 PM
pulgaleakimports
Sep 14, 2004 02:06 PM
lastpunkinline
15
Feb 11, 2004 11:04 AM
