B18A1 engine?
Old Jun 24, 2004 | 04:21 PM
stackz's Avatar
at the jetties fishin'
Community Builder
Default B18A1 engine?
would this engine be worth anything if it runs? we got in an older integra and it's got this in it. Think I'll see if it runs tomorrow then don't know.
how much different from later model B18's is it aside from say electronics?
If I knew it could be made like the later model B18's I might just toss it in my 98 but if it couldn't be updated to OBDII then I wont worry about it.
Old Jun 24, 2004 | 04:24 PM
Greasemonkey's Avatar
I think the main difference between the two is that A1 is ObdI and B is OBDII. not worth it. get an OBDII engine.
Old Jun 24, 2004 | 06:55 PM
Bseriescivic5's Avatar
get a conversion harness for it and your fine, i sell em bout 150 bucks, check em out at backmotorsports.com
Old Jun 24, 2004 | 07:38 PM
skip.two's Avatar
Default Re: B18A1 engine? (stackz)
B18A's use cable trannies.
B18B's use hydro trannies
http://www.clubcivic.com/board/specs.php
Old Jun 25, 2004 | 06:02 AM
13sechatch's Avatar
b18a1 obdo 130 hp
b18b obd1 and obd2 142 hp slight difference in the build up but nothing to major
Old Jun 25, 2004 | 08:14 AM
zer0.'s Avatar
Default Re: (13sechatch)
the 92-93 B18A1s have like 2-4 less hp than the 94-01 motors....no real differencein the motor itself..i had a 93 B18A1 in my 94 hatch and paired it with a hydrolic GSR tranny and it was great. the motor only had 70k original miles on it as well.
Old Jun 25, 2004 | 09:12 AM
Nextelbuddy's Avatar
Default Re: (zer0_2_6ixty)
90-91 integra b18a1 motors are obd0 and 92-93 integra b18a1 motors are obd1 but they still haev a cable tranny. get a 92-93 b18a1 and mate it with a b series hydro tranny and you will be set.
Old Jun 25, 2004 | 11:25 AM
stackz's Avatar
Community Builder
Default Re: (NextelBuddy)
so the later b18b distributor and intake manifold wont work on the b18a1??
Old Jun 25, 2004 | 11:53 AM
zer0.'s Avatar
Default Re: (stackz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz &raquo;</TD></TR><TR><TD CLASS="quote">so the later b18b distributor and intake manifold wont work on the b18a1??</TD></TR></TABLE>
there's no reason why it shouldn't work. if you compare the 92-93 B18A1s to the 94-95 B18B1s the only difference is that the 92-93s have a cable tranny.....cosmetically the only difference is the "A1" in the block #
OverBoostDemon
14
Sep 8, 2009 09:00 PM
Firewalkerz
Aug 7, 2007 09:19 AM
Elemental
Aug 5, 2004 09:15 PM
bulldog_RS20
Jun 5, 2002 09:39 AM
