Is building a b18B engine worth it?
Old Aug 2, 2004 | 11:05 PM
Elemental's Avatar
Default Is building a b18B engine worth it?
As im watching all these videos on our local site, I realize... people are going to remember this guy because he was something special. he went above what other people were doing. he moved away some time ago, and people still talk about how great his work was.
I have an integra ls. stock everything for now. I want to know if its worth building a b18b1 engine. Ive seen videos of b18c1 engines cranking out huge numbers. Will a b18b1 engine ever create those kinds of numbers?
Screw N/A. Lets not even mention it. I am talking turbo. Lots of PSI. Lots of HP AND torque. Anyone seeing 10's out of these engines... even 11's?
Thanks for help.
Old Aug 2, 2004 | 11:15 PM
smelldaOdaa's Avatar
Default Re: Is building a b18B engine worth it? (Kyoushu)
u want more torque??? GET A VW 1.8T ENGINE!!!! just playin, i just miss my golf thats all
Old Aug 2, 2004 | 11:21 PM
Elemental's Avatar
man if i liked torque, I wouldnt have gotten a honda.
Old Aug 3, 2004 | 02:46 PM
Elemental's Avatar
bump
my goal is 300 whp and 225 lbft of torque.
is this possible with a daily driven b18b1 engine? maybe ls/vtec?
Old Aug 3, 2004 | 09:16 PM
ragerized's Avatar
Default Re: (Kyoushu)
you could make that with ls/vtec on like 6-8 lbs, depending on tuning
Old Aug 3, 2004 | 09:49 PM
ek9800's Avatar
Default Re: (ragerized)
swap it to a GSR. LS are really not that reliable look for more threads youll see most likely nothing but problems with them
Old Aug 4, 2004 | 06:35 AM
InLimbo87's Avatar
Default Re: (jdm98hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm98hb &raquo;</TD></TR><TR><TD CLASS="quote">swap it to a GSR. LS are really not that reliable look for more threads youll see most likely nothing but problems with them</TD></TR></TABLE>
hmmm.... that was an ignorant comment. he was talking about building his anyways. There's a guy with a full interior ls on drag radials running 11's on team-integra. He's got a fully built b18b1 and is puttin out somewhere around 400 whp.
Thats w/ GE sleeves, eagle rods, wiseco pistons, ARP headstuds, cometic headgasket, and get this a DRAG 3 KIT!!
Old Aug 4, 2004 | 07:49 AM
StyleTEG's Avatar
your full of ****
Old Aug 4, 2004 | 08:31 AM
97L-esVeeTeg's Avatar
Default Re: (StyleTEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG &raquo;</TD></TR><TR><TD CLASS="quote">
your full of **** </TD></TR></TABLE>
styleteg is very correct, there's a number of guys using non-vtec motors making good power, NA and FI, as a matter of fact some people prefer the LS engine for turbo appilcations. A well tuned LS Setup can be a blast and with headwork 300hp is attainable and well worth the time and money.
Old Aug 4, 2004 | 08:46 AM
b18bme's Avatar
Default Re: (97L-esVeeTeg)
What a ***** Bag!
Old Aug 4, 2004 | 12:02 PM
ek9800's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97L-esVeeTeg &raquo;</TD></TR><TR><TD CLASS="quote">
styleteg is very correct, there's a number of guys using non-vtec motors making good power, NA and FI, as a matter of fact some people prefer the LS engine for turbo appilcations. A well tuned LS Setup can be a blast and with headwork 300hp is attainable and well worth the time and money.</TD></TR></TABLE>
Oh my bad i didnt read the part where he said he wanted to go turbo i just saw the N/a part.
Old Aug 4, 2004 | 12:24 PM
StyleTEG's Avatar
Even NA they are problem free.
Old Aug 4, 2004 | 12:36 PM
ek9800's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG &raquo;</TD></TR><TR><TD CLASS="quote">Even NA they are problem free.</TD></TR></TABLE>
i wouldnt say all that now.
Old Aug 4, 2004 | 04:27 PM
StyleTEG's Avatar
I have first hand experiance that they are.
Why comment on a subject that you only have "herd" about?
Old Aug 5, 2004 | 02:14 PM
ek9800's Avatar
i mena i know people wit this swap and its not the best the oil pump isnt good or anything. basically the money that u spend on making it a decent motor is enopuch money that u could buy a "good" swap with IMO
Old Aug 5, 2004 | 02:19 PM
StyleTEG's Avatar
ugh, no.
$3,000 for a GSR motor
or $500 for a B18B and $2,500 to build it up.... hmmm?
Old Aug 5, 2004 | 03:53 PM
PureTeg420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm98hb &raquo;</TD></TR><TR><TD CLASS="quote">i mena i know people wit this swap and its not the best the oil pump isnt good or anything. basically the money that u spend on making it a decent motor is enopuch money that u could buy a "good" swap with IMO</TD></TR></TABLE>
haha wow, you're trying to argue that the LS motor is bad because of the oil pump it comes with? Maybe you should go to a thread/forum where you actually have a slight ounce of knowlege on what your talking about. I have been running 373whp with pump gas on my "POS" b18b for over a year now with many compromises for street driving, and the only problem I've run into is my tires wear out a bit too fast. Just cause your friends don't know how to correctly build a motor, doesn't mean that the b18b is a poor base to start with.
Old Aug 5, 2004 | 04:05 PM
9SECQTR's Avatar
Default Re: (PureTeg420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PureTeg420 &raquo;</TD></TR><TR><TD CLASS="quote">
haha wow, you're trying to argue that the LS motor is bad because of the oil pump it comes with? Maybe you should go to a thread/forum where you actually have a slight ounce of knowlege on what your talking about. I have been running 373whp with pump gas on my "POS" b18b for over a year now with many compromises for street driving, and the only problem I've run into is my tires wear out a bit too fast. Just cause your friends don't know how to correctly build a motor, doesn't mean that the b18b is a poor base to start with.</TD></TR></TABLE>
TY
2 years ago I made 309 at 10-11 psi with a stock motor
we are looking to push anywhere from 630-660 after i get my car to kens custom chassis and the body shop
and yes it is an ls fully built turboed motor
Old Aug 5, 2004 | 06:39 PM
Elemental's Avatar
Default Re: (9SECQTR)
o damn! good luck with that man. Unfortunately, I didnt have the knowledge to swap the b18b into a hatch, so i am stuck with this heavy *** integra body.
Well I am going to read. and read and read. So 9secqtr, what is your setup? if you dont mind me asking.
Old Aug 5, 2004 | 06:54 PM
ek9800's Avatar
ok first of ALL U NEED TO STOP BEING A FLAMER did u read at the end i said In My Opinion (IMO) so just chill
Modified by jdm98hb at 8:04 PM 8/5/2004
Old Aug 5, 2004 | 06:58 PM
StyleTEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm98hb &raquo;</TD></TR><TR><TD CLASS="quote">ok first of LL U NEED TO STOP BEING A FLAMER did u read at the end i said In My Opinion (IMO) so just chill</TD></TR></TABLE>
your opinion is wrong
Old Aug 5, 2004 | 08:25 PM
ek9800's Avatar
maybe to you but not to me thanks
Old Aug 5, 2004 | 09:15 PM
9SECQTR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyoushu &raquo;</TD></TR><TR><TD CLASS="quote">
Well I am going to read. and read and read. So 9secqtr, what is your setup? if you dont mind me asking.</TD></TR></TABLE>
no i dont mind
Built for the SFWD class
10.28:1 cp pistons, custom eagle rods, darton pro mid sleeves, jg turbo cams and built head, external oil pump, aeromotive fuel pump 1200cc injectors, jg manifold and t-body, AEM ems, Turbonetics T-72 turbo and racegate, greddy bov...lots more
we are going to try to achieve the 650 mark at around 26-28 psi hopefully we can do it in less i will also be spraying a 55 shot just for some help spooling the turbo.
It should be done (fully I hope) for the NOPI nationals.
1 week at Kens Kustom Chassis 1 week in the body shop and then just install the motor I hope I have it done by then.
EvilEyez
Aug 1, 2006 10:54 AM
WAFFLES
37
Aug 6, 2003 03:41 PM
VTECTIME
Dec 14, 2002 05:56 PM
Nick H
Mar 19, 2002 06:45 PM
