Engine building: help with bearing codes
Old Jun 24, 2004 | 03:30 PM
pip9's Avatar
Default Engine building: help with bearing codes
How can i tell what bearing i need for my motor (rod & main)? On the side of the block it says CCBCC. I'll have the letters and numbers off of the crank tomorrow.
Anyone have a chart or something so i can tell what colors to get?
Old Jun 25, 2004 | 10:48 AM
pip9's Avatar
Default Re: Engine building: help with bearing codes (pip9)
bump
Old Jun 25, 2004 | 11:29 AM
leadfoot78's Avatar
You will need a Helms manual for that, or you can post your numbers and letters here and someone with the manual can tell you what you need. If you will assemble the block yourself you should still get the Helms manual anyway.
Old Jun 25, 2004 | 11:38 AM
hatchbackhonda's Avatar
Default Re: Engine building: help with bearing codes (leadfoot78)
just took my numbers and letter codes and took it to my local honda dealership and they had a list and ordered them for me that is what i would do i would trust a honda dealership's list over a helms list but that is my opinion
Old Jun 25, 2004 | 12:12 PM
pip9's Avatar
Default Re: Engine building: help with bearing codes (hatchbackhonda)
Here's the codes. pulley ---> flywheel
letters: CCBC
numbers: 32322
block:
ccbcc
I think the letters on the block go with the numbers on the crank for the main bearings right?
and the letters on the crank are for the rods bearings?
Old Jun 25, 2004 | 12:17 PM
DavidR's Avatar
If this is correct:
Pulley -> Flywheel
C3 C2 B3 C2 C2
Then:
C3= Brown
C2= Green
B3= Green
Old Jun 25, 2004 | 01:13 PM
pip9's Avatar
Default Re: Engine building: help with bearing codes (DavidR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidR &raquo;</TD></TR><TR><TD CLASS="quote">If this is correct:
Pulley -&gt; Flywheel
C3 C2 B3 C2 C2
Then:
C3= Brown
C2= Green
B3= Green</TD></TR></TABLE>
sweet
what about the rods bearings?
Old Jun 25, 2004 | 01:21 PM
DavidR's Avatar
you need the numbers off the rods before we can determine that.
Old Jun 25, 2004 | 01:28 PM
pip9's Avatar
i didnt see any numbers on the rods. they are eagle rods. I looked at the stock ones and all the markings on them are the same. ???
Old Jun 25, 2004 | 01:38 PM
DavidR's Avatar
Ok, then your bearings will be
Pulley - Flywhee
C3 C3 B3 C3
C3= Brown
B3 = Green
What I have quoted is for B series engines. If this is D, I have no reference in front of me
Old Jun 26, 2004 | 02:08 AM
leadfoot78's Avatar
Your Honda dealership probably used a Helms manual to check the codes for you.
SnoopyMan
Nov 21, 2012 06:54 PM
Midori Green
Apr 6, 2008 09:37 PM
92civtegra
Feb 29, 2008 04:24 PM
ubreak_ubuy
Apr 29, 2004 03:36 PM
drewlee
Sep 22, 2003 12:18 PM
