Need help with cai installation
Hey guys I just bought this intake: http://cgi.ebay.com/ebaymotors...38634
They didn't include any intallation instructions, so I was wondering if any one of you guys have any pictures or pdf files I can download.
Thanks, Brent.
Thanks, Brent.
1. Disconnect line going to stock air tube.
2. Unscrew hose clamp on throttle body that connects the air tube.
3. Unbolt airbox (3 10mm bolts).
4. Pull it all off.
5. You're left with a little air ram next to the radiator, pull that off.
6. You're left with the resonator under the airbox which is under the body.
7. Unscrew fender lining and pull away (not all of it, unscrew front of the lining where it connects to the bumper).
8. Unbnolt resonator (if I remember correctly, 2 10mm bolts).
9. Drop it down. If your car is too low, jack up car until there is enough clearance to remove it.
10. Get CAI out and clamp coupling to the intake side and clamp filter to the filter side.
11. Slide coupling to the throttle body and clamp down.
12. Connect air line to the air hose you disconnected from the stock location.
13. Connect CAI with coupling after running the piping (which has the filter on it) through the hole where the OEM resonator and airbox was).
14. Replace fender liner.
15. Go vroom vroom around the block.
16. Don't get used to WOT (flooring it) because the sound will get you used to flooring it all the time to show off your sound.
17. When you drive past someone at WOT, scream "m4d tYt3 v-t3ch y0!"
4. Pull it all off.
myuglycivic
Aug 17, 2005 06:56 PM
civic_on_13s
Jul 28, 2003 05:25 PM
Hon-duhhh
Nov 9, 2002 10:23 PM
