help info on Cold air intake
Re: help info on Cold air intake (civic_on_13s)
you have got to be kidding me.
if you cant do it just by looking, or reading instructions that should come with it, then you need to have someone else do it.
kthxbye.
kthxbye.
First start off by removing the stock intake and all of it's tubing. You should not need to jack up your car because you can get to the resonator via the fender well.
Re: (civic_on_13s)
Just go ahead and do it, its fairly simple. Remove the intake tubing from underneath the hood, and the filter box, should be like 2 bolts. Pull back the fender lining or take off the front bumper to get access to the resonator box, and remove that, which should be like another 2 bolts, and you're done.
http://www.leftcoastimports.com/cai-intake.htm
Not the exact same but gives you an idea how simple it is.
Re: (civic_on_13s)
the hardest part is actually getting the filter in the fender well. other than that, it's really just a couple of bolts. and if you need, just get a manual and follow the instructions on how to pull all the old stuff off. really a piece of cake job.
Re: help info on Cold air intake (Damon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Damon »</TD></TR><TR><TD CLASS="quote">you have got to be kidding me.
kthxbye.</TD></TR></TABLE>
Don't Flame ... There is First time for everything have a
Re: help info on Cold air intake (Lysawy)
u can learn to do it by just looking at a bunch of pictures from mags. or online..its pretty hard to screw up the install so bad that u can t just redo it if things don t go right the first time..*pretty tough*
i install d the filter to the CAI behind the wheel well
Jettplane
07-10-2012 05:23 PM
Omega Blaze
08-17-2008 07:54 AM
