boosting stock d15b2 with d16z6 head
Old Jun 24, 2004 | 12:45 PM
Layziebtnh055's Avatar
Default boosting stock d15b2 with d16z6 head
ok, i knw your getting ready to say search nobe or something like that, i did search im wondering if i can boost my mini me or nnot
Old Jun 24, 2004 | 12:55 PM
null.'s Avatar
Default Re: boosting stock d15b2 with d16z6 head (Layziebtnh055)
just watch your compression and you'll be fine, solution = thicker head gaskets. and might as well build the block while you are doing hte mini-me. and the d15b2 block is one strong sucker
Old Jul 6, 2004 | 04:04 AM
bump
Old Jul 6, 2004 | 10:54 AM
89dxhunchback's Avatar
Yea, just get a 2mm head gasket. Mini-mes compression is too high IMO for boost. I perfer 9/1 and under for turbo cars running more than 7psi daily, but most choose to push there luck ( or buy a $1000 e.m.s. ), which is why you see a lot of "I blew my motor" threads...
Does any Daily drivien honda really need more than 300whp ? Hell the D-series can make that with low compression....
Old Jul 6, 2004 | 02:13 PM
TurboCRXPERT1's Avatar
I have a d16a6 block with a z6 head,z6 head gasket oem, and I have been running 8lbs of boost for like 8 months on my daily driver with no management other than bigger injectors and afc hack. Oh, and I beat the **** out of the motor 24/7. Runs like a champ, even compression all across.
delslo93
Dec 2, 2004 04:47 PM
mrmechanic
Sep 12, 2004 05:40 PM
xXx Justin xXx
Oct 9, 2003 03:18 AM
ZeroAccess
Jun 23, 2003 03:09 AM
