HELP! rpm/ acceleration problem
Old Jun 24, 2004 | 09:00 AM
rtpassini's Avatar
Default HELP! rpm/ acceleration problem
i put an h23 in my sol. and im still having some problems.
when i try holding it at a certian rpm it doesnt stay smooth. its very choppy.
also, sometimes itll just bog down instead of rising up in rpms. what the hell is wrong.....(oh yeah, im also throwing code 12 and 14. i dont have the egr hooked up. (yet) and my IAC appears to be fine. the idle is smooth. when i unplug it then it goes crazy, when i plug it in, its fine...whys it still throwing the code?)
Old Jun 24, 2004 | 08:41 PM
rtpassini's Avatar
Default Re: HELP! rpm/ acceleration problem (rtpassini)
anyone?
Old Jun 25, 2004 | 12:17 AM
ThisLittleSleepeR's Avatar
did you check the tps sensor and the IAC? if so did you clear the codes? dumb answer but some people dont clear it. try that and see if the codes still pop up
wstsydr
Jan 8, 2008 08:02 PM
NJcivic21
Nov 9, 2005 11:44 AM
rtpassini
Jun 27, 2004 02:42 PM
89POS
11
May 27, 2004 01:58 PM
