adjusting 98+ headlights
i tried moving the dials w/ a no 2 screwdriver, but the light doesnt move. im trying to adjust the horizontal angle, but it doesnt do anything. i did about 20 full rotations and it did not change. help? thx
20 full rotations of the screwdriver? or 20 full rotations of the gear wheel? 96 and up have an 8mm hex head I think on the gear wheel, but it will probably require something like a ratcheting gear wrench to be able to use that to adjust, due to space limitations. That will be ablot faster than a screwdriver.
http://www.team-integra.net/se...D=388
u have to be registered to use team-integra.net
for the 98+ headlight, I parked about 30Ft away, and turned 30 times clockwise(vertical adj) before I saw any changes. Give it a few more spin, Otherwise, the headlight adjustment unit may have been damaged.
yeah i had this problem and ended up leaving it messed up for awhile. but you just need to spin some more. i sat there and spun the damn thing for 10 min and thats when i started to notice movement. so i think just take your time. plus you may want to look at this site, gives you a good description on how to:
http://www.autooptiks.com/aiming.html
goodluck
goodluck
Adjusting your headlight can be very time consuming and frustrating it is also very easy to throw all the adjustment settings out of spec. If I were you I would take it in to the dealership and have them adjust it. It can't be that expensive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kendogg »</TD></TR><TR><TD CLASS="quote">im having trouble as well
bump for us!</TD></TR></TABLE>
me too
bump for us!</TD></TR></TABLE>me too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brand »</TD></TR><TR><TD CLASS="quote">http://www.team-integra.net/se...D=388
u have to be registered to use team-integra.net</TD></TR></TABLE>
thats waht i did, also shows u how in the car manual.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">20 full rotations of the screwdriver? or 20 full rotations of the gear wheel? 96 and up have an 8mm hex head I think on the gear wheel, but it will probably require something like a ratcheting gear wrench to be able to use that to adjust, due to space limitations. That will be ablot faster than a screwdriver.</TD></TR></TABLE>
about 20 w/ the dial.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrmonk »</TD></TR><TR><TD CLASS="quote">Adjusting your headlight can be very time consuming and frustrating it is also very easy to throw all the adjustment settings out of spec. If I were you I would take it in to the dealership and have them adjust it. It can't be that expensive.</TD></TR></TABLE>
i would like to see where im going.
loki2323
Jan 16, 2005 11:30 AM
