Trailing Arm Bushings
Old Jun 23, 2004 | 09:14 PM
.:TNN:RumbleN:.'s Avatar
Default Trailing Arm Bushings
Im not sure where to post this. I made a post about this before. Basically now I need to know the size difference between the rear trailing arm bushing on a 92-95 civic and 90-93 integra. I did a rear disc swap, and decided to put in new bushings. Now, I was TOLD that the new trailing arms/disc assembly was from a 93 integra gsr. The bushings i got were for a 93 civc, but the box said they would fit a 93 integra too. But they dont.....
I really need your guy's help here. The Mugen bushings are over 100 bux i cant afford to order the wrong ones again
Thanks in advance!
Old Jun 25, 2004 | 01:09 AM
Default Re: Trailing Arm Bushings (.:TNN:RumbleN:.)
bump
Old Jun 25, 2004 | 03:45 AM
pdiggitydogg's Avatar
Let me guess....they fall right out of the hole?
da arms ta bushings are 10.5" circumference
eg/dc/ek arms ta bushings are 10" circ.
you need different bushings
If you just bought them and didnt use em you can send them back.
OR you could get a shop to fab up a ring to slide over the bushings, making it 10.5" circ.
Did you buy them from KingMotorSports?
cangrin
Jan 20, 2009 09:50 AM
cangrin
Jan 19, 2009 10:40 PM
Timberland237
Nov 20, 2006 08:00 PM
mrtoastyjr
May 4, 2004 10:40 PM
RacerBoy
12
Apr 3, 2003 08:06 AM
