Tachometer Problem in a 92 hatch 2001B18c1
Old Jun 23, 2004 | 05:06 PM
HybridHatchC1's Avatar
Default Tachometer Problem in a 92 hatch 2001B18c1
I have a 92 hatchback(car never had a tach before) with a 2001 GSR swap and a 95 gsr dash swap.
i hooked everything up and got no tach signal. so i ran a new wire from the distributor down to the harness for the tach signal wire. Now it just sits there and when i hit the throttle the tach will make a random atempt to read the signal( it with jump around) but its not even sychronized with the throttle. It will just somtimes jump
then i tryed a autometer tach and got the same problem. then i checked all the continuity(sp) and every connection that was made was good.
I dunno guys i am stuck and frustrated and would just like to move on to other things but i need to get this worked out. Any help would be appreciated.
Old Jun 23, 2004 | 05:59 PM
Default Re: Tachometer Problem in a 92 hatch 2001B18c1 (HybridHatchC1)
Bump for some help...might hit this problem up tonight if i can get a answer
Old Jun 23, 2004 | 06:01 PM
chad's Avatar
Moderator
what wire harness are you using?
if it is a 00 harness then you will need to run a wire from your dizzy to the blue wire on the shock tower on driverside...then your tach will work
Old Jun 23, 2004 | 06:50 PM
Default Re: Tachometer Problem in a 92 hatch 2001B18c1 (chad)
yea its the 01 harness, i was told i needed to hit a pin at the ecu for the tach to work because the 99-01 motors use a crank sensor for a more accurate reading? i dunno if its true.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">what wire harness are you using?
the tach tester wire? or a blue wire in a harness? can i get a better description?
Old Jun 24, 2004 | 08:06 AM
I found the wire and i am still getting a shitty signal... when i am on the gas the tach is like barried reads like past the oem marks goes to like 15k. I think the guy i talked to is right and i have to get the signal at the ecu... Anyone know which wire?
Old Jun 24, 2004 | 09:13 AM
Evil_Wizard's Avatar
On a 2000 and 2001 GSR the tach gets its signal from the ECU and VSS not the distributor. You have to run a wire from the ECU to the gauge cluster. Let me know if you need to know what color wire it is.
Old Jun 25, 2004 | 09:48 AM
Default Re: Tachometer Problem in a 92 hatch 2001B18c1 (Evil_Wizard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil_Wizard &raquo;</TD></TR><TR><TD CLASS="quote">On a 2000 and 2001 GSR the tach gets its signal from the ECU and VSS not the distributor. You have to run a wire from the ECU to the gauge cluster. Let me know if you need to know what color wire it is. </TD></TR></TABLE>
Yep i sure do, can you help me out with the color man?
Old Jun 26, 2004 | 10:07 AM
If I rememner right it is green with a red stripe, but it is raining now so I will have to wait until it stops to go out and let you know for sure.
Old Jun 27, 2004 | 10:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil_Wizard &raquo;</TD></TR><TR><TD CLASS="quote">If I rememner right it is green with a red stripe, but it is raining now so I will have to wait until it stops to go out and let you know for sure.</TD></TR></TABLE>
aight man just waiting on you...help me out
Old Jun 27, 2004 | 11:33 AM
94coupeNA's Avatar
you said you installed an autometer tach and it still didn't work? Well I just installed mine last night and it didn't work at first too! IF and only IF your tach is brand new...you might have to cut those little loop wires behind the tach...I think its the blue first....try that....if that don't work then cut both blue and brown. That's only if you didn't try cutting it already! LOL that's what i forgot to do, and when i hit the throttle full blast the needle read only 2 grand... o.O !!! its all G now...COBALT AUTOMETER IS SEXY AT NIGHT!!!! good luck man
Old Jun 28, 2004 | 07:12 AM
Default Re: Tachometer Problem in a 92 hatch 2001B18c1 (94coupeNA)
its not the autometer man i cant even get the stock tach reading right... but in the autometer directions it tells you to cut those wires, thier for 6cly and 8cly cars.
Old Jun 28, 2004 | 04:22 PM
Alright it is in the largest of the three plugs down at the ECU. The wire is a red wire green stripe and has silver dots on it. Then you have to run it to the back of the gauge cluster. And on the cluster the largest plug has a blue wire there. Tap into that wire and you should have a working tach.
Old Jun 29, 2004 | 08:12 PM
got the tach working man thanks for your help... now i have to finish up wraping the door panels, carpet, steering wheel, seats and it will be ready for a photoshoot.
donvito#1
27
Apr 30, 2008 02:35 PM
dthug
Jan 3, 2007 07:27 AM
egHondas4Life
Jun 9, 2005 07:34 PM
C5eg
Jan 10, 2003 11:54 AM
