HELP WITH CHECK ENGINE CODES=3,7,43
Old Jun 23, 2004 | 04:10 PM
oldirt3277's Avatar
New User
Default HELP WITH CHECK ENGINE CODES=3,7,43
HELLO ALL AND THANKS FOR THE CODES LISTS BUT WHERE DO I FIND INFO ON THIS CODE
43 FUEL SUPPLY SYSTEM WHAT PART OF IT IS FAULTY?
7 THROTTLE POSITION SENSOR ANYONE KNOW WHERE FOR CHEAP?
3 MAP SENSOR CHEAP REFERENCE?
ANY HELP WOULD BE GREATLY APPRECIATED
Old Jun 23, 2004 | 04:31 PM
2lua's Avatar
Default Re: HELP WITH CHECK ENGINE CODES=3,7,43 (oldirt3277)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldirt3277 &raquo;</TD></TR><TR><TD CLASS="quote">HELLO ALL AND THANKS FOR THE CODES LISTS BUT WHERE DO I FIND INFO ON THIS CODE
ANY HELP WOULD BE GREATLY APPRECIATED</TD></TR></TABLE>
what year and model?
43= check your gas cap.
7= check your wiring. if it bad. it is not going to cheap cause at the dealer only sell it with throttle body, and the tps is rivitted on the throttle body.
3= check to see if it got clogged up or dirty.
1000_miles
Dec 20, 2006 03:28 PM
crxtech
Mar 30, 2006 06:35 AM
igone916
Mar 3, 2003 08:59 PM
