EK: auto to manual questions
okay i searched far and wide and just wanted to make sure everything i serached it correct. for this ek auto to manual (well i was going to do a b18c1 swap at the same time) i need to get the master clutch cylinder and the pedal assembly right?! the ecu, tranny, shift linkage, etc will come from the motor i will buy. is there anything else i have to purchase to make it work? different shift linkage? shifter? any help is appreciated
You need the manual passenger side transmission mount bracket,the one thats welded to the frame.Its different from the auto.You will also need the slave cylinder,which should be bolted to the tranny you get.
Needs to be welded on...the old auto mount needs to have all of the spot welds drilled out,than it should come off..may need a chisel/flathead screwdriver to help.The new one needs to be welded on in the same position as the auto bracket though.And its just the bracket that needs to be welded,the mount bolts to the tranny.
Thanks, I have an EK, and I'm about to do the auto to manual myself and I needed to know if it requires welding. If it doesn't, this has just made my life easier!
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
Nah man, EKs require no welding. Consider yourself lucky beeeyotch! (Jk) I'm splittin my head here trying to find somewhere I can rent a welder from. Good Luck with the swap!
There is no welding on the EK and there is no welding on the EG if you get the auto to manual mount.
JDMShit! sells the mount for a great price!
We have done a total of 4 auto to manual swaps this year and both EG (one EG hatch and a delsol) swaps have left our shop with that mount.
The other 2 were an EK coupe and a 94-97 Accord. Neither of them needed welding, just the manual mount and it bolted in perfectly.
just one more question: will the eg parts fit on the ek? (master cylinder, slave cylinder, and pedal assembly and shift assembly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbarbulo »</TD></TR><TR><TD CLASS="quote">no one mentioned the hydraulic lines for the clutch... or will the fluid just transfer from master to slave through thin air? :D</TD></TR></TABLE>
You never know nowadays.
EKSedAndy
Jan 9, 2011 03:41 PM
Ssaacckkeedd
13
Mar 13, 2007 02:37 PM
b16dragger
Mar 29, 2004 12:36 PM
