Head swap
Old Jun 23, 2004 | 12:15 AM
Coby's Avatar
Default Head swap
Bearing in mind that I live in South Africa, where we dont have a big range of honda engines, which cylider heads will or can be made to fit D16A block.
Old Jun 23, 2004 | 07:05 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: Head swap (Coby)
WHICH D16A block? D16A6? D16A1? D16A3? That makes a huge difference.
Old Jun 23, 2004 | 09:59 PM
Coby's Avatar
Default Re: Head swap (tjbizzo)
It is a D16A7
Old Jun 24, 2004 | 06:23 AM
tjbizzo's Avatar
Never heard of that one before. Are you sure it doesn't say D16A1 with a big serif on the one? What car does it come in?
Old Jun 24, 2004 | 06:27 AM
Kendall's Avatar
The D16A7, like many of Honda's engine codes, is specific to one continent. I believe that the A7 is a single cam, however I'm unsure as to whether it is a VTEC engine or not. If it is a VTEC engine, then there is no practical reason to swap the head, however if it is a non-VTEC engine, then finding a VTEC head would be most beneficial.
Old Jun 24, 2004 | 06:32 AM
Coby's Avatar
Default Re: (Kendall)
Correct! It's a single cam 16v non vtec.
Old Jun 24, 2004 | 06:45 AM
Kendall's Avatar
In that case, try to locate a head from a D16Z6 and a P28 ECU. Also get a complete gasket set for the head, and a new timing belt. Do some research on the "Minime" swap to find out more.
Old Jun 24, 2004 | 07:01 AM
Coby's Avatar
Unfortunately I don't think that engine is available in our country. All VTecs here are DOHC. Thanx anyway any other suggestions?
Old Jun 24, 2004 | 07:42 AM
Kendall's Avatar
Buy one off of someone here on Honda-Tech, and have them send it to you.
Old Jun 24, 2004 | 07:52 AM
Coby's Avatar
With the Rand to Dollar rate as it is , and import duties, I don't think that would be possible. It would be too expensive. The Rand is currently trading at R6,68 to buy 1 dollar.
duramax guy
Honda Civic (2001 - 2005)
Mar 3, 2013 01:21 PM
bigsnorlax
Sep 29, 2008 09:09 AM
tei344
Jun 29, 2007 10:47 AM
stock_honda_coupe
32
Jul 31, 2006 08:51 PM
birdxa
Jan 10, 2005 08:31 PM
