Car used to burn oil, now it doesn't?
Old Jun 22, 2004 | 10:51 PM
SilverDc2's Avatar
Default Car used to burn oil, now it doesn't?
To start off i bought my car 2 years old, and since day 1 i've used mobil 1...used to burn a little then at a certain point it was burning 1 quart every oil change.
Now, with double the milage it's not burning anything....i mean nothing, i just changed my oil and exactly what i put came out?.....pretty weird....i've been running my car a little harder than normal too....
has this happen to anyone else?
Old Jun 22, 2004 | 10:57 PM
LSTEG96's Avatar
Default Re: Car used to burn oil, now it doesn't? (SilverDc2)
carbon build up has probably sealed ur motor... dont sea foam it! (i think that ***** called sea foam...?)
Old Jun 22, 2004 | 11:16 PM
FR-MOB: ThE bEe GuY's Avatar
Did you stick with the same oil the whole time? I heard Mobil 1 burns a lot more than a lot of other companies oils.
Old Jun 23, 2004 | 12:34 PM
SilverDc2's Avatar
Default Re: Car used to burn oil, now it doesn't? (ThE bEe GuY)
yup, i've been used it for the last 4 years on my car....
Old Jun 23, 2004 | 01:10 PM
IntEGNYC's Avatar
maybe its a good thing
Old Jun 23, 2004 | 01:16 PM
Two_K Si's Avatar
Default Re: Car used to burn oil, now it doesn't? (IntEGNYC)
Maybe when you picked up the car, the rings were stuck and with the use of mobil 1 they were freed up by its detergent package. Synthetics do have good cleaning properties so that could be the reason.
JDM_Andrew
Feb 4, 2009 03:02 PM
sniperslayer
Nov 1, 2008 07:53 AM
Extreez
Aug 3, 2006 10:47 PM
98cwitr
Jan 3, 2003 10:37 PM
Seann
Feb 6, 2002 07:17 AM
