Gears for N/A?
Old Jun 22, 2004 | 07:37 PM
95cxGSR's Avatar
Default Gears for N/A?
I am currently running a gsr tranny, i want to know if i should buy 4.7 itr final drive, should i buy a b16 tranny. Or just run the gsr. I want to stay N/A and ive heard it will drop my et by .2, .3 and gain 4, 5 mph in the 1/4 . Ur suggestions will help.
Thanx
Old Jun 23, 2004 | 06:17 AM
dfoxengr's Avatar
Default Re: Gears for N/A? (95cxGSR)
motor and car/suspension setup is....?
Old Jun 23, 2004 | 01:25 PM
95cxGSR's Avatar
Default Re: Gears for N/A? (hybridvteceg)
My car is a 95 civic hb cx. Motor is a 95 gsr, like my name says. As for now im running skunk2 coilovers and stock struts. (probably blown) But I plan on goin wit ground control or tein. Im also planning to do alittle headwork and bigger cams. I want to go low 13's high 12's daily driven.
Old Jun 23, 2004 | 01:48 PM
pills's Avatar
id go wit a ctr tranny, really close gears.
Old Jun 24, 2004 | 10:53 AM
Circuit Star-29's Avatar
Default Re: Gears for N/A? (pills)
CTR tranny has the same gearing as a USDM ITR tranny and JDM S1/Y1 and USDM SC4/Y21
If you want to get the shortest gearing, I'd say use the Final Drive kit from a JDM ITR tranny. You'll run out of gears really quickly, though, so top speed...don't consider it to be very high. Like 130 or so. Consider your street driving, too. Good luck.
Don't forget about TRACTION. (LSD) This would be My first change. You can get a LSD with the final drive on it but I'm not sure if you can find the shaft, gear and other parts for it.
http://www.bseries.net/html/specs/btrannyspecs.php
lopey
Apr 4, 2006 05:42 PM
gsrintgra98
Jun 1, 2003 07:04 PM
gsrintgra98
May 19, 2003 10:33 AM
gsrintgra98
May 19, 2003 10:19 AM
Anyotherone
Oct 3, 2002 01:16 PM
