can you use a SOHC greddy turbo kit on a gsr swap?
Old Jun 22, 2004 | 05:49 PM
s2000june's Avatar
Default can you use a SOHC greddy turbo kit on a gsr swap?
i wanna buy a turbo kit but. its for a sohc motor.. what all would i have to change to use on my gsr motor.
i know i need a new turbo manifold so it will bolt to my b-series but is that it.. if any 1 has had this problem or has done this change over let me know .
thanks
Old Jun 22, 2004 | 05:53 PM
Jimmy's Avatar
Global Moderator
No you cannot/ should not try to change it over.
The turbo manifold isn't going to fit and unless the turbo you have for the SOHC is a t3..because it would be pointless to use a t25 or a greddy 14b on a b-series motor.
Sell your sohc kit and buy a b-series kit.
Old Jun 22, 2004 | 05:55 PM
ICUinMYrearview's Avatar
Default Re: (Jimmy)
not 100% sure but a friend of mine had a SOHC turbo kit on his GSR integra for quite a while. Just drilled the manifold out and used it....at least I am 99% sure thats what he had.
B_CRUZ!'s Avatar
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">No you cannot/ should not try to change it over.
Sell your sohc kit and buy a b-series kit.</TD></TR></TABLE>
sadly enough I have seen someone do it. ghetto fab. they even used the sohc turbo manifold
leaks up the ying yang...
Old Jun 22, 2004 | 05:58 PM
Default Re: (BDCruz)
this particular GSR was built boosted and sprayed. no sleeves just pistons and rods however. Went 12.1s on the small turbo if I remember correctly
Old Jun 22, 2004 | 05:59 PM
Jimmy's Avatar
Global Moderator
Default Re: (ICUinMYrearview)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICUinMYrearview &raquo;</TD></TR><TR><TD CLASS="quote">this particular GSR was built boosted and sprayed. no sleeves just pistons and rods however. Went 12.1s on the small turbo if I remember correctly</TD></TR></TABLE>
Then good for him..
Old Jun 22, 2004 | 06:02 PM
Default Re: (Jimmy)
Then good for him..</TD></TR></TABLE>
sarcasm??? I am just sayin that it can be done...would I do it...hell no, its worth the $$ in my opinion to go head and get a turbo built for the kinda motor that u have. no since in riggin something up.
Old Jun 22, 2004 | 06:15 PM
s2000june's Avatar
yo yo no hating fellas. i just need some help thanks for the info booth of yall. anything helps. if i get the kit i would just buy a bseries mani.. come out way cheapier than buying a whole bseries kit. im sure i could get 100 for the sohc turb mani.
Old Jun 22, 2004 | 09:12 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: can you use a SOHC greddy turbo kit on a gsr swap? (civicrida3)
I would suggest asking the questions in the correct forum or searching for yourself. No sense in getting answers with other's personal preference or opinion, when you can easily find a more reliable answer for yourself.
Here:
https://honda-tech.com/zerothread?id=802680
https://honda-tech.com/zerothread?id=371737
https://honda-tech.com/zerothread?id=654453
https://honda-tech.com/zerothread?id=586400
https://honda-tech.com/zerothread?id=725879
And if anyone would like to play devil's advocate and argue against the original poster's decision, they can start here:
https://honda-tech.com/zerothread?id=267752
no_rice_please
Jan 7, 2007 07:05 AM
GSRHATCH187
Nov 20, 2003 07:42 PM
d15b7racer
Oct 8, 2003 06:48 AM
beakert216
Aug 23, 2002 03:32 PM
prjctCIVIC
Jul 22, 2001 10:59 PM
