stock headgasket 24psi???
I blew my cometic because I was using stock head bolts.Now the gasket is on backorder!I now have ARP studs and thought of using a stock gasket until the cometic came in.It is on a zc and the honda gasket is not a multi layer metal gasket like a B-series.Do you think it will hold??????????
are you saying that you were running a cometic head gasket with STOCK head bolts @ 24 psi?? or is this what you are planning on running(PSI)?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si »</TD></TR><TR><TD CLASS="quote">yes stock headbolts and 24psi and it blew the cometic in half
What I want to know is.....how the **** did stock HONDA head bolts withstand 24 psi!!!!!!!!!!! what size turbo are you running?
</TD></TR></TABLE>What I want to know is.....how the **** did stock HONDA head bolts withstand 24 psi!!!!!!!!!!! what size turbo are you running?
He is not running a traditional multi-layer OEM headgasket like what is on the Gsr, etc. The ZC headgasket is not like that. I would do some more research to see what head gaskets may fit OEM style.
T3to4b and believe it or not it held for thirty dyno runs and 3 passes down the track.I did some research and nothing honda/acura will match up physically or by part#, for the headgasket that is.
boomslang
Sep 18, 2002 12:48 PM
the stock gasket held 11psi and lasted for 2 years until I pulled the motor to build it!!!
