Beaks Rear Lower Tie Bar
Old Jun 22, 2004 | 04:17 PM
salvatore's Avatar
Default Beaks Rear Lower Tie Bar
has anyone tried the Beaks tie bar?
$100 and it SHOULD fit right in with the itr sway bar and their kit.
i know the whole tie bar / itr sway bar subject has been beaten to death but i wanted to see if anyone had tried the beaks tie bar.
is it worth it or is it some piece of crap like the dc tie bar?
Old Jun 23, 2004 | 08:06 PM
salvatore's Avatar
Default Re: Beaks Rear Lower Tie Bar (salvatore)
biggity bump
Old Jun 24, 2004 | 11:44 PM
salvatore's Avatar
bump
Old Jun 25, 2004 | 01:10 AM
Two_K Si's Avatar
The beaks appears to be a multi piece tie bar. I would go with a cusco or carbing tie bar as they are one piece and can be had for around $70.
EDIT: The beaks is a multi piece but has no pivot points, so it looks good. Still the cusco/carbing tie bars are cheaper and perform the same.
Old Jun 25, 2004 | 02:29 AM
JFG Kevin's Avatar
Default Re: Beaks Rear Lower Tie Bar (Two_K Si)
the i have the beaks mount kit for the itr sway bar.....i was also thinkin about gettin a beaks tie bar...but it looks so low to the ground...wonder if it will have clearance problem
Old Jun 25, 2004 | 01:16 PM
Cramerox's Avatar
Default Re: Beaks Rear Lower Tie Bar (aznstyler119)
its a piece of crap sal...you dont need it.
Old Jun 26, 2004 | 12:46 AM
salvatore's Avatar
Default Re: Beaks Rear Lower Tie Bar (Cramerox)
sup. i was not really going to buy it.
it got some bling tho
Old Jun 26, 2004 | 09:17 AM
Timmy!'s Avatar
Ya the bling factor has come and steal me all over it. But it looks sweet.
SCCAsean
Mar 23, 2006 12:14 AM
Kyles ej1
Suspension & Brakes
Mar 27, 2005 12:17 PM
JFG Kevin
Mar 23, 2004 04:33 AM
SloCivicHMM
12
May 19, 2003 11:45 AM
IntEGNYC
Jan 10, 2003 10:38 AM
