reving out at 6000 RPM with a JDM Type R Integra Comp
My b16 is reving out at 6000 RPMs as if it was hitting the rev limiter. Any recomendations for that problem? I am getting a Knock Sensor code from my ecu.
The knock sensor code causes the ECU to shift the fuel cut to where VTEC would normally kick in. Either there's a problem with the knock sensor somewhere, or you have some knock somewhere.
