Converting automatic PR3 ecu to manual...
What are the benifits?... By changing the jumper points will this up the redline to 8200 from 7500, or does it just change the fuel maps? I searched and all I can find is how to convert it but it doesn't explain what it accually does.
TIA
TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">Need to look harder
http://www.pgmfi.org/twiki/bin...anual</TD></TR></TABLE>
I found that by searching on here, but what I need to know is what does it change how does it accually d when you move the jumper.
my guess is that it will throw codes if you try to chip it with a "manual" chip. therefore you change the jumpers.
but with stock chip. I can't see it changing the revlimit. or fuel maps. that info is in the chip. "software" not hardware.
possibly it wont run right with manual "hardware" and auto "software" (stock chip)
Needs to be About 20% Cooler
the auto ecu has a gear selector switch and when in gear, the ecu keeps the motor runing from the TC' load.
that's my understanding, i dont know if this true or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JC18 »</TD></TR><TR><TD CLASS="quote">the auto ecu has a gear selector switch and when in gear, the ecu keeps the motor runing from the TC' load.
that's my understanding, i dont know if this true or not.</TD></TR></TABLE>
Kool, bump for more info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer »</TD></TR><TR><TD CLASS="quote">bump for wanting to know the same thing! Does this mod change the redline or no?</TD></TR></TABLE>
No your redline is based on the program that is burned on the chip
sohc_freak
15
Apr 22, 2006 03:26 PM
MonkeyMagic
May 15, 2004 08:32 AM
