Del Sol, Dies, need help.
Old Jun 22, 2004 | 10:09 AM
R1Gal's Avatar
Default Del Sol, Dies, need help.
Hi-
I'm have a problem with my '93 Del Sol. I can be driving on the interstate at say 3k RPM.Cruising along without any problems, all of the sudden the tach will start jumping to 3500 -4500 RPM, car still running fine, then it will start dropping anywhere from 0 RPM (car actually cuts off) but will pick back up, but if fluctuates form 1000 - 3000 RPM, and the car is surging along. Eventually it will die on side of the road. I know the main relay is good, I just put a new one on it. Any one had this problem or something similar?
Old Jun 22, 2004 | 10:50 AM
azndelseoul3's Avatar
Default Re: Del Sol, Dies, need help. (R1Gal)
i kinda had the same problem but it was my alternator...
Old Jun 22, 2004 | 10:58 AM
delScho's Avatar
Default Re: Del Sol, Dies, need help. (azndelseoul3)
That sounds exactly like a bad alternator. Maybe tell us if it starts back up?
Old Jun 22, 2004 | 12:25 PM
R1Gal's Avatar
delScho-
Yea, it will after I let it sit a few minutes. Sometimes it will crank and run a few seconds and go dead again. Actually and honestly i put a main relay off my Civic on it, (Ordered a new one today). It just started doing this last night, when I turned the heater on. I had the top off and heater on (Lol)..
I cleaned all the connections under the hood, and reattached also cleaned the ones under the distributor cap. Was your car doing the same thing? (Tach jumping up and then going down?)
Lil' AznKid
11
Jul 16, 2012 12:44 PM
joshsdelslow
Sep 2, 2011 04:46 PM
Motown Del Sol
Oct 18, 2010 05:04 PM
SisterFister
Apr 4, 2010 10:28 AM
YEL-MEL
Jun 23, 2003 05:52 AM
