are all Integra trans share the same parts ie. inter. shaft, clutch, flywheel ??
Are they like the single cams where all of there trans, clutch, and flywheel are interchangeable like the 89-00 D series?
Will an 94-00 manual intermediate shaft work on a 92-93 cable ls trans? and will a 92-93 clutch work on a 94-00 flywheel on a 93 ls motor ? or
Or do they have to stay within their generations 90-91;92-93; 94-00?
sorry for newb questions but im a single cam guy switching over and i need help cause im searching for parts in the dark?
thanks for the help guys
i know that part. i need to know if all the parts are compatible. as well as interchangeable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RuthlessEF-9 »</TD></TR><TR><TD CLASS="quote">i know that part. i need to know if all the parts are compatible. as well as interchangeable.</TD></TR></TABLE>
yah. the stock models may differ, gsr/type r and ls will have different clutch/ flywheel. they are all interchangeable.
so i can run a 94-00 intermediate shaft on a 92-93 cable trans?
and will a 92-93 clutch fit a 94-00 flywheel?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 »</TD></TR><TR><TD CLASS="quote">
yah. the stock models may differ, gsr/type r and ls will have different clutch/ flywheel. they are all interchangeable.</TD></TR></TABLE>
gsr's and ls's use the same clutch, and the type r has its own clutch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost fed ls »</TD></TR><TR><TD CLASS="quote">
gsr's and ls's use the same clutch, and the type r has its own clutch</TD></TR></TABLE>
but u can use all three clutches in any number of combinations.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RuthlessEF-9 »</TD></TR><TR><TD CLASS="quote">so i can run a 94-00 intermediate shaft on a 92-93 cable trans?
and will a 92-93 clutch fit a 94-00 flywheel?</TD></TR></TABLE>
flywheels yes, intermediate shaft.... i dunno, hydro 94-00 and cable 92-93...hm.
gsr's and type r's can use the same clutch though as far as i know, at least you can put a type r clutch in a gsr
this is a good question that someone else asked before. check the spline diameter on the clutch and if they match you should be ok
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sabotage7 »</TD></TR><TR><TD CLASS="quote">gsr's and type r's can use the same clutch though as far as i know, at least you can put a type r clutch in a gsr</TD></TR></TABLE>
The friction disks are the same, but the ITR has a stiffer (and more expensive) pressure plate
All the hydro Bs' have interchangable clutch components though.
.All the hydro Bs' have interchangable clutch components though.
impreziv
Jul 20, 2008 10:53 AM
Origin
Sep 11, 2005 08:00 PM
giooooo
Oct 3, 2002 02:36 PM
91, 9293, 9400, acura, ass, clutch, clutches, compatible, integra, interchangeability, intermediate, shaft, type, work
