wheel sensors
I read that my ABS light is coming on because ABS pump is not getting a "wheel turning" signal from one of the wheel sensors. How would I go about finding out which of the 4 sensors is bad?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport »</TD></TR><TR><TD CLASS="quote">anybody know what the other connector is for? I know the blue one is for CELs, how about the other?</TD></TR></TABLE>
this 5 pin one?
it's for a diagnostic computer (PGMFI tester or HDS- Honda Diagnostic System)
this 5 pin one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quazar »</TD></TR><TR><TD CLASS="quote">do I have to remove the radio to get to it?</TD></TR></TABLE>
No, you don't. You can reach it just behind the radio from the pedals area.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quazar »</TD></TR><TR><TD CLASS="quote">once you get the code, where is the reference key? thanks</TD></TR></TABLE>
In helms
Tell me your code, I'll tell you what to fix
In helms
Whats up man. I got 3 blinks about 5 seconds apart when I shorted the connector.
What code is that? Thanks for your time man.
By the way. Could you send me your e-mail address. I think my membership here has a time limit. quazar2k@hotmail.com
Thanks again, I really appriciate the help.
I have the same question you do quazar. I have been trying to figure out how to access and work the diagnostic socket terminals as my ABS light on by Gen 4 lude is on. Pentaq showed me this post. I found this sheet on the web that gives the codes for Accord Prelud Legend and Concerto.
Below it the site
http://www.bba-reman.com/hondaalb2computer.htm
Here is a copy of what is on that site hope this helps.
By the way, was it easy for you to get behind the radio and test it? I am going to try tomorrow
Honda ALB2 ABS computer - fault codes.
Fault codes: how to access. Turn igniton off. Bridge diagnostic socket terminals. Turn ignition on. If ecu is ok warning should come on for 2 seconds and then go out for 2 seconds. The lamp should then begin to flash. The first set of short flashes indicate the first number of the fault code. A brief pause seperates each flash. A medium pause seperates each group of flashes. If there are more than one code stored a long pause seperates each trouble code.
Code
Fault
1 Hydraulic pump motor over-run (contact BBA)
1-2 Hydraulic pump motor (contact BBA)
1-3 High pressure leak (possibly modulator)
1-4 Pressure switch (contact BBA)
1-8 Pressure accumulator
2-1 Handbrake warning lamp switch circuit faulty
3-1 Right hand front rotor damage
3-2 Left hand front rotor damage
3-4 Right hand rear rotor damage
3-8 Left hand rear rotor damage
3-12 Different tyre sizes fitted
4-1 Right hand front wheel sensor
4-2 Left hand front wheel sensor
4-4 Right hand rear wheel sensor
4-8 Left hand rear wheel sensor
5-4 Right hand rear wheel lock
5-8 Left hand rear wheel lock
6-1 Front fail safe relay
6-4 Rear fail safe relay
7-1 Right hand front modulator solenoid valve
7-2 Left hand front modulator solenoid valve
8-1 ABS operation fault
8-2 Electronic control unit (ECU) fault
8-4 Electronic control unit (ECU) - internal circuit fault
Below it the site
Code
Fault
