Throwing up gang signs? Nah, just throwing codes CEL style:
Yup, "Motor Power Creator" keeps bringing these ones back... Or maybe it's God's test pipe?
Here they are:
Code: 71, 72, 73, 74
Was there a list online here? I know we all keep asking the same damn questions...
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
sounds like someone is ripe for a helms manual.....
They were all on back order for a long time... I dunno if they have them in stock now. I used that money to buy other stuff!
71 Random Misfire (Cyl 1)
72 Random Misfire (Cyl 2)
73 Random Misfire (Cyl 3)
74 Random Misfire (Cyl 4)
Ignition system, fuel supply system, MAP sensor, IAC valve, contaminated fuel, lack of fuel, fuel injector, fuel injector circuit, low compression, valve clearance
http://www.clubsi.com/error_codes.shtml
Will
Will
Any OBDII car with B's will throw these 4 codes...............
Here's the weird thing: it didn't come on for like 2 months after I added the godspeed test pipe. But since resetting it a couple of times, it comes on after 20 min of driving... I'm pretty much giving up on resetting it.
It also seems to make the car run differently now too... Idle is higher... What is the ecu doing? Compensating how? By backing off timing? It's not in limp mode, is it? (Sure doesn't feel like it...)
Kenny, i checked those from day one, but i only get 71 and 72...weird.
Chris.....
Quit your bragging...
.. lol.
So you liking the FC? i wanna see how much it helps when tuned
LATA
[Modified by TodaCivic, 10:13 AM 11/16/2001]
Chris.....
.. lol.So you liking the FC? i wanna see how much it helps when tuned
LATA
Im running JUN III, i never got the misfire code until my speed sensor messed up. Im running an ITR ECU odd one O2 sensor but no CEL. What i did was take the secondary O2 sensor, and plug it into the header bung. I took the primary 02 sensor and hung it behind the engine block, no CEL for 3 months
OT: That is the most orignal and funny name of a topic I have seen since I've been on H-T.
Glad you liked it.
More to come.....
my99ekcoupe
16
Sep 1, 2010 09:45 PM
Drinker
