distributor obd2b to obd1 coversion
Old Jun 21, 2004 | 07:58 PM
mdj_ge's Avatar
Default distributor obd2b to obd1 coversion
who knows how to do it??? i'm doing a 2001 jdm h22a swap in a si eg hatch... i have two harness on the si wiring and one harness on the h22a... help me out... thanks in advance...
Old Jun 21, 2004 | 09:16 PM
Turbogixxer's Avatar
Default Re: distributor obd2b to obd1 coversion (yangja)
http://we-todd-did-racing.com/...DE%3D
Old Jun 22, 2004 | 03:20 PM
mdj_ge's Avatar
Default Re: distributor obd2b to obd1 coversion (turbogixxer)
Thanks so much for the info….. all the wires match up, but I don’t see the dark blue on the h22a harness… everything goes well with the conversion but it’s just that there is one extra wire on the d16z and I can’t find the dark blue on the h22a… please let me know where to find it, thanks….
Old Jun 22, 2004 | 03:27 PM
mdj_ge's Avatar
There is one more thing… there is a black plug on the top of the intake manifold, don’t know what it is called but it has a logo (Denso), on the h22 it has three wires on the harness and on the d16z it has two… how do I re-wire that… any help is appreciated… thanks
Old Jun 22, 2004 | 07:21 PM
mdj_ge's Avatar
i really need help on this...
Old Jun 22, 2004 | 07:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yangja &raquo;</TD></TR><TR><TD CLASS="quote"> there is a black plug on the top of the intake manifold, don’t know what it is called but it has a logo (Denso), on the h22 it has three wires on the harness and on the d16z it has two… how do I re-wire that</TD></TR></TABLE>
It is in between the injectors? If so, it is not needed.
Old Jun 22, 2004 | 07:46 PM
mdj_ge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
It is in between the injectors? If so, it is not needed. </TD></TR></TABLE>
you mean u don't need to hook it up...
Old Jun 22, 2004 | 07:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yangja &raquo;</TD></TR><TR><TD CLASS="quote"> you mean u don't need to hook it up... </TD></TR></TABLE>
Correct, OBD1 does not use it
Old Jun 22, 2004 | 08:15 PM
mdj_ge's Avatar
Correct, OBD1 does not use it</TD></TR></TABLE>
actually the d16z harness do have that sensor too... so ur saying it's useless.... what's the function for it anyways... this is the sensor on the intake manifold... if u look it on the gsr engines... it's the sensor on the middle of the top manifold...
Old Jun 22, 2004 | 08:18 PM
mdj_ge's Avatar
if anyone knows to hook up the dark blue wire on the distributor, please help me out on that one...
Old Jun 22, 2004 | 08:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yangja &raquo;</TD></TR><TR><TD CLASS="quote"> if anyone knows to hook up the dark blue wire on the distributor, please help me out on that one... </TD></TR></TABLE>
You are talking about the Blue wire that is on the two wire connector? That is ignition out. You do not need it. You tach will work. IF you tach does not work, hard wire that wire to the guage cluster.
Old Jun 22, 2004 | 08:47 PM
mdj_ge's Avatar
You are talking about the Blue wire that is on the two wire connector? That is ignition out. You do not need it. You tach will work. IF you tach does not work, hard wire that wire to the guage cluster.</TD></TR></TABLE>
turbogixxer, thanks man... you've been a great helper... i'll try that...
sirtef9
Jul 16, 2008 05:51 AM
jinxster
May 30, 2003 11:46 AM
gameovr
Jun 5, 2002 01:54 PM
