sooo i go to change my oil...
Old Jun 21, 2004 | 04:35 PM
gac_gonejeepin's Avatar
Default sooo i go to change my oil...
and find my drain plug completely rounded off. 17mm socket just spins its ***** off...
anyone run into this problem before? guess i'll wait til i get to the shop tomorrow and get it on the lift and rip the bitch out. new drain plug here i come.
also doing mobil-1 5w-30 with a new fram x2 filter. running some engine restore and fuel injector cleaner through it. try to keep it reliable until the swap goes through.
---gabriel
Old Jun 21, 2004 | 04:55 PM
Default Re: sooo i go to change my oil... (gac_gonejeepin)
i just love this forum.
---gabriel
Old Jun 21, 2004 | 04:58 PM
87b16crx's Avatar
if i were you i would go to the honda dealer and get an oem one. they are prolly cheaper and i have read that they are designed to hold a certain oil pressure. to much filtration might give you a low pressure reading. which could efect vtec if you are so equiped.
Old Jun 21, 2004 | 05:17 PM
fourthgenhatchB17's Avatar
Default Re: (87b16crx)
Get some vice grips to take that rounded bolt off.
Old Jun 21, 2004 | 05:19 PM
Nature's Renewal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">Get some vice grips to take that rounded bolt off.</TD></TR></TABLE> then go buy a magnetic drain plug from pepboys.
Old Jun 21, 2004 | 05:24 PM
zc honda's Avatar
vice grips rule!!,
or u can buy the special sockets from sears designed to grip striped bolts, they work pretty well
Old Jun 21, 2004 | 05:26 PM
Default Re: (zc honda)
yea doing the vise grips as soon as i can get the car up in the air enough to get some kind of leverage.
just read about fram's quick valve oil drain system. think i'll try that out.
---gabriel
Old Jun 21, 2004 | 05:41 PM
h89crxsi's Avatar
Default Re: (gac_gonejeepin)
gator grip socket will work and i also recomend the magnetic drain plug
Old Jun 21, 2004 | 05:43 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 87b16crx &raquo;</TD></TR><TR><TD CLASS="quote">if i were you i would go to the honda dealer and get an oem one. they are prolly cheaper and i have read that they are designed to hold a certain oil pressure. to much filtration might give you a low pressure reading. which could efect vtec if you are so equiped.</TD></TR></TABLE>
i wouldnt get the dealer one either, they are made by fram and fram is garbage...
get a napa gold which is made by wix and is a very good filter...
Old Jun 21, 2004 | 06:17 PM
LSVTEC 91 Civic's Avatar
Banned
Mobil 1 ownz j0o.
Edit: So does magnetic SPOON plugs
Modified by LSVTEC 91 Civic at 3:57 AM 6/22/2004
Old Jun 21, 2004 | 06:54 PM
b16_madman's Avatar
Default Re: (LSVTEC 91 Civic)
my swap came w/the quick drain plugs...grrr, don't have the tool to "quick" drain it
gotta use a adj. wrench
Old Jun 21, 2004 | 08:24 PM
87b16crx's Avatar
Default Re: (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">
get a napa gold which is made by wix and is a very good filter... </TD></TR></TABLE>
not anymore. they have filtech making them now.
Old Jun 22, 2004 | 06:05 PM
vtecrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gac_gonejeepin &raquo;</TD></TR><TR><TD CLASS="quote">yea doing the vise grips as soon as i can get the car up in the air enough to get some kind of leverage.
---gabriel</TD></TR></TABLE>
dont get the fram quick drain oil thing unless you like waiting 15 minutes for your oil to drain. I used mine once and tossed it
Old Jun 22, 2004 | 06:07 PM
riceburners1's Avatar
not to thread jack but whats the use of magnetic drain plugs???
Old Jun 22, 2004 | 06:11 PM
Banned
Default Re: (riceburners1)
To collect metallic materials in your oil.
Old Jun 22, 2004 | 06:24 PM
learn something new everyday....and wow thats a great idea....i gotta get one of them for the next oil change
Old Jun 22, 2004 | 06:31 PM
Banned
Yuh, I got teh SPOON plugs y0, transmission and engine. SPOON ownz j0o.
Old Jun 22, 2004 | 06:36 PM
xci_ed6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt get the dealer one either, they are made by fram and fram is garbage... </TD></TR></TABLE>
You couldn't be more wrong. The new (civic) filters are made by Filtech, I believe. The S2k and hybrid filters are still made by the old manufacturers. I will get their names tomorrow.
tolnep's Avatar
check out http://www.cantonracingproducts.com/
They have some real nice oil filter solutions amongst other things. Reusaable canisters. Better than anything your gonna get from Fram/dealer/honda etc...
Old Jun 22, 2004 | 06:37 PM
xci_ed6's Avatar
Default Re: (krustindumm)
oh, drain plugs are ~$2, but I bet you need a new pan too.
Old Jun 22, 2004 | 06:53 PM
Proper's Avatar
careful with the Frahm quick drain too. If your car is lowered and you hit a good sized bump that fitting hangs a lot lower than your factory plug and your oil will be all over the street.
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">
the s2k is made by toyo roki, same company that makes the HAMP ones...here is where it says new honda filter made by fram...so...there...
https://honda-tech.com/zerothread?id=616464
https://honda-tech.com/zerothread?id=238268
https://honda-tech.com/zerothread?id=659592
Old Jun 22, 2004 | 07:15 PM
xci_ed6's Avatar
Doesn't metter to me, the literature honda gave me says it is manufactured by filtech.
FYI:
Every honda has the same oil filter <u>except</u> for the S2K (larger) and the Hybrid (smaller).
They are interchangeable as far as fitment, but function is unknown.
I would run the S2k filter if you are worried about it, I think I will be for the increased capacity.
Old Jun 22, 2004 | 07:16 PM
crxgator's Avatar
or just get a napa gold which is made by wix and your set without paying dealer prices for a filter...
and its the same size as the "old" ones which is still made by every manu'...
Old Jun 22, 2004 | 07:22 PM
pokemon's Avatar
It is good to have a close friend that works at the dealer. I use all Honda OEM ****. If you can have a 88 civic and the stock motor still runs strong as hell with 200,xxx miles on it using a OEM oil filter is good enough reason for me. ;]
