i have 89 crx si no engine,cx engine from a 94 civic hatch,and greedy turbo kit?
can i just put the turbo in and leave it at low boost ? and if low how high can i have it before i see a piston fly at my face!
30 psi? Thats crazy on a stock motor. Maybe on a built motor. Depending on location you wouldn't want to run more than 5-8 psi without a intercooler. Do you have an intercooler? You could run more but be carefull. Without the right air/fuel mix it will probally detonate.
30 psi!
on a stock d15b7! that **** will blow it out! i need a good rate psi like 5-9! maybe
on a stock d15b7! that **** will blow it out! i need a good rate psi like 5-9! maybeTrending Topics
omg 30psi is like shoving a fire hydrant hose up ur *** n turnin it on... lol. omg, dont listen to that guy, thats so crazy its suicide! 9psi max is what i would do, since its not a built motor.
7 psi max with stock internals.
a friend of mine turned his boost up to 45psi on his awd talon and blew every valve spring and piston in the engine
Guest
Posts: n/a
I thought the 30psi part was funny as hell. Hell it's a cx motor so it pretty weak so don't expect crazy **** out of it in the first place but why in the hell would any put a cx motor in a crx in the anyway?
candyman3106
May 28, 2005 01:59 PM
Duck Sauce
Nov 26, 2001 02:43 PM
