Compression test analysis
Old Jun 21, 2004 | 02:17 PM
LSVTEC 91 Civic's Avatar
Banned
Default Compression test analysis
Cyl 1 - 310, cyl 2 - 310, cyl 3 - 275, cyl 4 - 310
Opinions?
Engine - LSVTEC w/ ITR head & CTR pistons.
Modified by LSVTEC 91 Civic at 11:35 PM 6/21/2004
Old Jun 21, 2004 | 02:25 PM
Tushner's Avatar
Default Re: Compression test analysis (LSVTEC 91 Civic)
Dry or wet?
Old Jun 21, 2004 | 02:34 PM
Banned
Default Re: Compression test analysis (redteg_87)
Wet, test done after car was driven.
Old Jun 21, 2004 | 06:19 PM
Banned
ttt
Old Jun 21, 2004 | 06:24 PM
Behan's Avatar
something is definetly wrong in the no. 3 cyl. variance between cylinders shouldn't be more than 20 psi IIRC.
Old Jun 21, 2004 | 06:37 PM
Banned
Default Re: Compression test analysis (Behan)
Was told it could possibly be valve adjustment - no oil burn and spark plug for no. 3 looks great, like all the others.
Old Jun 21, 2004 | 06:57 PM
GZERO's Avatar
when he asked if wet he meant if you poured a teaspoon of oil in the cylinder and then measure the compression, this will tell you if it is rings, if you say is valve out of adjustment sounds fair, do it and measure compression.
Old Jun 21, 2004 | 07:09 PM
Banned
Default Re: Compression test analysis (GZERO)
No, I didn't put oil in the cylinders. Would that raise pressure reading, or lower it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GZERO &raquo;</TD></TR><TR><TD CLASS="quote">when he asked if wet he meant if you poured a teaspoon of oil in the cylinder and then measure the compression, this will tell you if it is rings, if you say is valve out of adjustment sounds fair, do it and measure compression.</TD></TR></TABLE>
Old Jun 21, 2004 | 07:21 PM
GZERO's Avatar
if is ring it should bring the compression up at least a lil, if is not then compression should remain around the same
Old Jun 21, 2004 | 07:36 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GZERO &raquo;</TD></TR><TR><TD CLASS="quote">if is ring it should bring the compression up at least a lil, if is not then compression should remain around the same</TD></TR></TABLE>
Thanks for clarifying. I'm not worried about it that much though... I hardly burn oil.
Old Jun 22, 2004 | 11:01 PM
Chubz's Avatar
oil in the cylinder doesnt tell you anything, adding anything to the cylinder is gonna raise PSI. Yes a valve adjustment might bring it up but maybe 15 psi at the most, if it even needs adjustment.
Old Jun 22, 2004 | 11:30 PM
Eluzion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Was told it could possibly be valve adjustment - no oil burn and spark plug for no. 3 looks great, like all the others. </TD></TR></TABLE>
Well, I'd definatly go with a valve adjustment first and see what happens. I always heard it will only help it a little bit but it helped me a ton. I'm running a built B16A (boosted) and I was getting these numbers:
140-158-158-170
Did it several times, did the oil trick and all the compression #'s shot up about 20psi. So I did a valve adjustment and came out with these numbers:
160-165-165-175
Still kind of odd why I have one that's so high lol but as you can see, it definatly helped me a great deal. I should probably adjust it again one of these days since I didn't have much time when I did adjust them (adjusted them pretty quickly so I know a few might be a tad off still which probably wont make much of a difference anyways). I just adjusted them to stock specs (.007 exhaust, .006 intake).
This is just from my experience, and it might not even have anything to do with your problem but oh well, figured I'd share the info cuz I was pulling my hair with the first compression #'s.
hutcho3
Apr 11, 2011 06:54 PM
lando griffin
Feb 12, 2008 10:39 PM
Fat Chick Magnet
Nov 22, 2006 09:52 PM
mafay2
Nov 11, 2004 07:34 PM
RedRacerCivic
11
May 22, 2003 10:29 AM
