is it ok to run oil feed line under/next to oil pan
Old Jun 21, 2004 | 02:01 PM
alfee's Avatar
Default is it ok to run oil feed line under/next to oil pan
is it ok to run my oil feed line under the turbo, between the oil pan and tranny upwards to the T in the back of the block? will this pose any problems? and does it matter which way the L shaped adapter for the feed line on the turbo faces up or downward?
Old Jun 21, 2004 | 02:09 PM
B18 CYA's Avatar
it should work. There is pressure through the line ... it is not like the return line which works through gravity
Old Jun 21, 2004 | 02:13 PM
alfee's Avatar
Default Re: (c2nap)
ok good, just needed another opinion of assurance 'cause not too sure about how hot the temperatures maybe down there and if it'll affect the ss braided line.
Old Jun 21, 2004 | 02:18 PM
nonvtecD's Avatar
Default Re: (alfee)
Isn't the oil in the pan the same as the oil in the line? you'll be fine
Old Jun 21, 2004 | 02:29 PM
alfee's Avatar
Default Re: (D15B7turbo)
haha thanks
Old Jun 21, 2004 | 08:26 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: (alfee)
i'll have mine run that way for appearance or lack there of.
Old Jun 28, 2004 | 04:10 PM
integra-modder's Avatar
Default Re: (not so civic)
The only problem I forsee with that is that you might have to take the turbo off if you need to take off the line. Mine was leaking at first so I actually used a 3 inch brass extension to bring it forward so that I could troubleshoot the leaks, and now Im too lazy to change it.
gabe768
May 22, 2010 01:18 PM
elcangripapi
Dec 20, 2006 04:17 PM
elcangripapi
Dec 20, 2006 04:16 PM
the.hamburglar
Jul 11, 2005 06:50 PM
redboost10
Oct 22, 2003 06:56 PM
