oil feed nipple fitment
1994 b18b1
what size connector do i need in order to connect my the oil feed line to the block? im tapping it in the usual oil sensor spot. and what do i do with the sensor? do i place a T there and connect the two? thanks
you need a MALE 1/8 BSPT to 1/8 NPT adaptor. The BSPT goes into your block and the NPT connects to the rest of your lines. I would NOT recommend connecting a "T" to the BSPT-NPT adaptor as engine vibration would slowly pull it out or cause it to break.
Check this site out.
http://www.theoldone.com/articles/oilpressure
You can Flamenco or Tuner Toys to get your proper fittings. Both have the fitting to the block but Tuner Toys has a T fitting that is 1 male bspt and 1 female bspt for the oil sensor and the NPT. I like the Tuner Toys fittings but its your call and your car--cant find it anywhere else, it was custom made for Tuner Toys.
You can check out our oil take off fittings here - http://shop.vendio.com/funinfeenix/category/4897/
