Getting through the firewall on a 95 prelude.
Old Jun 21, 2004 | 06:14 AM
tony92875's Avatar
Default Getting through the firewall on a 95 prelude.
Hey all,
I'm trying to run a 1 guage power wire from battery to trunk (for an amp of course). So far the only premade hole in the firewall that I can see is on the passengers side and comes out inside the car behind a ton of electrical components and other parts I'm not willing to unbolt right now. Is there another place to bring it through? Or another route altogether, bypassing the firewall? I don't mind running it up the drivers side of the car, either, since all other wires being ran are currently going up the passengers side.
Old Jun 21, 2004 | 06:34 AM
lildrgn2.0's Avatar
New User
Default Re: Getting through the firewall on a 95 prelude. (tony92875)
Nope. No other place. Use a coat hanger through the hold you found on the passenger side. It will come right underneath the AC I believe.
If not, just do like I did and cut your own hole. Dremel rules.
Old Jun 21, 2004 | 07:00 AM
Speedra500's Avatar
Default Re: Getting through the firewall on a 95 prelude. (Lildrgn)
You probably dont want to run your wire on the passenger side especially if you are running highs through your amp because you will get a whining noise, a good place to go is drilling near the pedals on the driver side, which will be a little ways under the master and slave cylinders
Old Jun 21, 2004 | 07:10 AM
PetroGuyX's Avatar
Right above the gas pedal is where i drilled a hole
zsiya
Oct 4, 2011 04:03 AM
junk95civ
Feb 21, 2010 05:31 PM
89beast
Honda Civic (2001 - 2005)
12
Sep 18, 2007 12:42 AM
Cool4u224
May 21, 2006 01:39 PM
Ochem2012
Aug 31, 2004 10:06 PM
