Oil leaking from exh. ports? Doesnt burn off though....
Old Jun 20, 2004 | 07:34 PM
Blaze45's Avatar
Brrraaaap!
Default Oil leaking from exh. ports? Doesnt burn off though....
I have noticed that oil is, well not really leaking, just seeping around the exh. ports. In the link is another link to pictures that show the problem that I am having. My motor runs strong and has solid compression in all 4 cyl. and doesnt lose any oil. I have not clue as to what is going on. Please, any insight would be great. tia
https://honda-tech.com/zerothread?id=869563
Blaze
Old Jun 21, 2004 | 07:41 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Oil leaking from exh. ports? Doesnt burn off though.... (Blaze45)
Nobody has any idea what this is?
Old Jun 21, 2004 | 08:18 PM
blackhatchb20's Avatar
my motor does the same thing...i dont even worry about it
Old Jun 22, 2004 | 10:45 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Oil leaking from exh. ports? Doesnt burn off though.... (blackhatchb20)
Anyone else?
Old Jun 23, 2004 | 08:21 AM
Circuit Star-29's Avatar
Rings and valve seals. Probably rings are shot.
Old Jun 23, 2004 | 10:31 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Oil leaking from exh. ports? Doesnt burn off though.... (nathan atwell)
Really? How does that explain solid compression across the board? Should I do a leakdown test? How could the rings be shot if the engine has under 25k on it? I dont understand eathier of the things that you threw out there. If the rings were bad, would the motor not perform to its potential and be noticeable? And if it were the valve seals, wouldnt I be burning oil? I am confused, an explantion of those 2 ideas that you threw out there would be great.
thanks
Blaze
Old Jun 23, 2004 | 11:57 AM
dcvt16's Avatar
change the gasket.
Old Jun 23, 2004 | 12:51 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Oil leaking from exh. ports? Doesnt burn off though.... (dcvt16)
Hm, never thought of that.
Blaze
Old Jun 27, 2004 | 09:20 PM
Well it depends how hard you push your engine. If your redline to redline-stop light to stop light, then yeah, your rings could get damaged. Your rings help keep oil down below the pistons and the valve seals keep the oil out of the exhaust port, so if either one of those fail then you'll get oil showing up like yours does. It could also be a header gasket. if you have a leak in it then where ever it blowing out will collect oil and dirt. check your compression again and your gasket. Good luck.
lilshady6796
May 24, 2009 04:07 PM
Rikaro
Nov 5, 2007 11:40 AM
Sassafrass
20
Jul 18, 2006 07:06 PM
red teg
Oct 9, 2005 03:33 PM
xlusiveracer
Sep 7, 2005 04:13 PM
