1996 ITR Engine Specs............
Are these specs correct ????????????
Taken from TotalJDM.com
Link:
http://www.totaljdm.com/index....m.htm
Cars: JDM 96-97 Integra Type-R
1797cc (DOHC VTEC)
Horsepower: 210hp@8100rpm
Torque: 134lbs-ft@7500rpm
Compression: 11.0:1
Bore: 81mm
Stroke: 87.2mm
OBD: 2
Redline: 8900rpm
Link:
1797cc (DOHC VTEC)
Compression: 11.0:1
Bore: 81mm
Stroke: 87.2mm
OBD: 2
Redline: 8900rpm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer »</TD></TR><TR><TD CLASS="quote">My 96 JDM ITR is OBD2 plug layout but the programming is OBD1. Euro ITRs are OBD2 plug layout also but i'm not sure which programming they use.....</TD></TR></TABLE>
I think the Euro ITR is just like the JDM, with an OBD1 P72 ECU and OBD2 plug layout.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmk2888 »</TD></TR><TR><TD CLASS="quote">That is what I thought exactly.
Also I thought the compression ratio is 11.1 not 11.0???????
Anyone else?????????</TD></TR></TABLE>
I have a 97........thats correct!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NSX Bob »</TD></TR><TR><TD CLASS="quote">HP and TQ look a little high to me.</TD></TR></TABLE>
The JDm b18C-R motors do net more whp and tq on the dyno than the USDM motors. My 97 JDM ITR dynoed stock with just a dc jdm 4-1 header at 175/125
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jelly Bean »</TD></TR><TR><TD CLASS="quote">
The JDm b18C-R motors do net more whp and tq on the dyno than the USDM motors. My 97 JDM ITR dynoed stock with just a dc jdm 4-1 header at 175/125</TD></TR></TABLE>
I got 174whp and 123wtq with 16" k1's, dc jdm 4-1 and comptech exhaust.
Well they were 200ps at 8000 which is equivalent to like 196-197hp. Torque was 18.5kg-m at 7500 which is like 133.2 lb-ft. The 98 Spec was the same ps numbers, but torque was 19.0 (136.8) made at 6200 rpms. Mostly due to the 4-1 header and the CTR exhaust cam from what I remember.
I put down 176whp, 126wtrq. w/ my 96 ITR swap+bolt ons.
Given a 15% drivetrain loss, that equals out to 202.4 flywheelHP and 144.9 flywheel trq.....the HP seems correct but the trq. seems high.
Therefore 200hp would be correct for a 96spec JDM ITR.
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
PS and BHP are not the same. Everyone thinks JDM is better, and for what a mugen headgasket is worth, the compression is slightly better but lets put it like this. 200PS equals approx. 197bhp.
Bottom line.
Compression : JDM 11.1 USDM 10.6
Japanese High grade gas - 98 octane
United States High Grade gas - 93 Octane (depending on location)
Difference in actual HP?? 2hp with .4 Higher compression and 5 octane points higher octane gas. Is it worth the difference? I say NO. Yeah, higher compression is good but if you really wanted power, i'd think most ppl would build the internals up and yes, the bottom end is a bitch, its worth doing if 2 HP is really that important.
Thats just my .02 cents
Bottom line.
Could you explain how the SAE HP are calculated ?
I 'm pretty sure it's without all accessories like alternator, power steering, air con compressor.....
The JDM and ISO DIN European HP are calculated with ALL Accessories.
1 HP = 1.0139cv DIN after, you have to apply the SAE or ISO corrected.
Modified by sylvain at 2:29 PM 6/23/2004
