Performance loss with CEL, anyone?
Would these codes be holding back power unfixed?
My swap is throwing the following codes:
Code 1- o2 sensor
Code 3- MAP sensor
Code 17- VSS (Vehicle Speed Sensor)
Code 43- Fuel Supply System
(used to run 14.41 @ 96.8 in my coupe, witch was over 100lbs more)
over a year 1/2 ago now I sold my 93 dx coupe w/ b20 swap (same as in car now) to some1 i knew at VA tech. a week after him getting the car it threw a CEL and staid on for a full year of him having the car. He said performance dropped very noticably. He then traded swaps with me and now I have the B20 swap in my hatch. The CEL's were still popping up on my car but Id flip the switch OFF then back ON to clear them (bout once a minute.. hah) well I just pulled the codes off to see what all was going on. I got the codes below:
Code 1- o2 sensor
Code 3- MAP sensor
Could these code be holding back power?
thanks again.
Code 1- o2 sensor
Code 3- MAP sensor
Code 1- o2 sensor
Code 3- MAP sensor
thanks again.
hm i don't have the answer to your questions, so somebody help this man out.
how does he know that performance dropped? you're both different drivers, and the 1 1/2 years build up mileage.
The coupe used to be mine and I put the swap in the coupe and ran the coupe. He baught the car and put only 8,500 miles on it. I got my old swap back and its as clean as ever but I have these CEL's to deal with now. I may not of explaind it right ... sorry
Idle is on the rough side and gas mileage is only about 20 mpg , so im assuming its running super rich.
The reason i'm asking that is because my topend isnt what it used to be and it used to ****** 4th on a regular bassis... haha
He said when the CEL came on for him performance dropped also every since, so hopfully I can get that light off.
Damn, you really need to fix those codes. They are very messing your car up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Typesi2nv »</TD></TR><TR><TD CLASS="quote">Code 1- o2 sensor</TD></TR></TABLE>
That is probably from a bad 02. What is the trim and year of your car?
Code 3- MAP sensor</TD></TR></TABLE>
Check the wires and switch the sensor out if teh wiring is ok. That will cause your bad gas mileage and the shitty idle. This is what mostly you are getting shitty proformance from.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Typesi2nv »</TD></TR><TR><TD CLASS="quote">Code 17- VSS (Vehicle Speed Sensor).</TD></TR></TABLE>
Also, check the wires and make sure everything is ok. I do not see VSS go bad (sensor wise).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Typesi2nv »</TD></TR><TR><TD CLASS="quote">Code 43- Fuel Supply System</TD></TR></TABLE>
This has to do with o2 sensor, see code 1 reply for info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">Damn, you really need to fix those codes. They are very messing your car up.
Yeah I know.. haha
Its not raining too much this week so I think I'm going to fix these codes when i get off from work tomorrow.
92' DX ; The guy said he replaced the o2 sensor the same week he got teh car from me. Could be wired wrong... I'll have to check that.
I threw this code the week before i sold him the car, It was because I had a Venom control box that had a wire going to the MAP sensor and when i took it off it made a loose connection. I tightend the wires up and teh code was gone I know until i left with the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">Also, check the wires and make sure everything is ok. I do not see VSS go bad (sensor wise).
I'll look for that, thanks
You've been a lot of help
Yeah I know.. haha
Its not raining too much this week so I think I'm going to fix these codes when i get off from work tomorrow.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">
92' DX ; The guy said he replaced the o2 sensor the same week he got teh car from me. Could be wired wrong... I'll have to check that.</TD></TR></TABLE>
DX has a Four wire o2 for the factory, so either someone messed with the wiring or you used a "general" o2. I have seen "general" not work or as good as OEM. What brand is the 02?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Typesi2nv »</TD></TR><TR><TD CLASS="quote">Yeah I know.. haha
Its not raining too much this week so I think I'm going to fix these codes when i get off from work tomorrow.</TD></TR></TABLE>
Good to see that you are fixing the car even after you sold the car. Most people would not.
Its not raining too much this week so I think I'm going to fix these codes when i get off from work tomorrow.</TD></TR></TABLE>Good to see that you are fixing the car even after you sold the car. Most people would not.
I rewired the o2 sensor , fiddled with the Mapsensor, andpushed on all the speed sensor wires.
all the check engine lights went off except the fuel system code. 43.
I checked the heat white wire for voltage and it sits at 0.00 when car is on. dont read any... shouldnt it read .1-.2 when its first started up and .1-.9 when its been running for a minute or so? I'mma bout to try a differnt o2 sensor, a one pc. OEM o2 sensor.. I've heard the universal aftermarket o2 sensors arnt very good and can have problems (this one is new)
The sensor has this on it
JAPAN
5420
11E24
I dont know the brand. Just know its a new sensor that has to be spliced.
JAPAN
5420
11E24
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Typesi2nv »</TD></TR><TR><TD CLASS="quote">Would these codes be holding back power unfixed?
Code 1- o2 sensor
Code 3- MAP sensor
Code 1- o2 sensor
Code 3- MAP sensor
thanks again.</TD></TR></TABLE>
Yes they are. MAP sensor alone throws you into limp mode, causing the motor to run rich and the timing being retarted.
Make sure those sensors are good and plugged properly and try resetting the ecu.
Code 1- o2 sensor
Code 3- MAP sensor
Code 1- o2 sensor
Code 3- MAP sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Typesi2nv »</TD></TR><TR><TD CLASS="quote">I rewired the o2 sensor , fiddled with the Mapsensor, andpushed on all the speed sensor wires.
JAPAN
5420
11E24
Hmm, no voltage? Check the continuity from the D14 pinout to the O2 sensor plug in the engine bay. Might as well check the rest of them as well.
D14 -> WHT wire.
A6 -> Org/Blk
A25 -> Yel/Blk
D22 -> Grn/Wht.
As for the VSS, make sure it's plugged in right and all the way.
JAPAN
5420
11E24
D14 -> WHT wire.
A6 -> Org/Blk
A25 -> Yel/Blk
D22 -> Grn/Wht.
ok thanks for the replies. If the weather is alright tomorrow I'll do some more troubleshooting. Hopefully i'll get this all fixed and the engine running to spec again.
Civic2Fast
Feb 11, 2003 07:19 PM
