Vapor Lock
Old Jun 20, 2004 | 01:31 PM
jeffb16's Avatar
Default Vapor Lock
I been having problems with my car starting sometimes when it is extremly hot outside. I just did a tune up (spark plugs, wires, etc) and the starter, distributor, battery, alternator, etc. are fine. A mechanic told me that I have vapor lock most likely. Anyone heard of "vapor lock" and does anyone know how to fix the problem?
Old Jun 20, 2004 | 01:40 PM
Jaesung's Avatar
Default Re: Vapor Lock (jeffb16)
how old is the car? never heard of that before "vapor lock"
Old Jun 20, 2004 | 03:58 PM
jeffb16's Avatar
Default Re: Vapor Lock (Jaesung)
It's not that old.. it's only a 92 Honda civic hatch with a JDM B16 (SI-RII).
Old Jun 20, 2004 | 04:00 PM
jeffb16's Avatar
My car not starting seems to be fuel related b/c sometimes when my car doesn't start I open the gas tank cover, unscrew the cap (which releases gas vapors), and then I start the car and it starts.
Old Jun 20, 2004 | 06:15 PM
LSVTEC 91 Civic's Avatar
Banned
Vapor lock is caused by a fuel getting to hot/boiling.. I have had this problem with my carbureted chevys, but never on a Honda.
Old Jun 20, 2004 | 06:50 PM
Stripped Honda's Avatar
99-0104
Default Re: Vapor Lock (LSVTEC 91 Civic)
it might be a bad main relay they cause the problem that when its hot outside it wont start and after it cools down in the car a little it will start ... just a thought i would throw out there ... sence i never heard of a honda vaporlocking
Old Jun 20, 2004 | 06:52 PM
ScottEK's Avatar
Default Re: Vapor Lock (Stripped Honda)
I bet you he has his gas tank vent capped off in the engine bay and got rid of the evaporation canister.
Old Jun 20, 2004 | 08:10 PM
Jimmy's Avatar
Global Moderator
I bet you that if you notice that your fuel pump isn't priming it's your PGM-FI main relay.
Here jOo go:
https://honda-tech.com/zerothre...36514
<FONT COLOR="red"> Your welcome</FONT>
Old Jun 21, 2004 | 10:18 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Vapor lock is caused by a fuel getting to hot/boiling.. I have had this problem with my carbureted chevys, but never on a Honda.</TD></TR></TABLE>Older carburated cars have a fuel pump that sucks fuel out of the tank. So the fuel in the line from the tank is at a partial vacuum, it vaporizes more easy, then it can't be pumped. Vapor lock mostly went away when they put electric pumps inside the tank.
Flakey main relay would be a likely guess.
Old Jun 21, 2004 | 05:12 PM
jeffb16's Avatar
Cool... I'll check the main relay and tell ya'll what happens. Thanks for your help.
Old Jun 21, 2004 | 08:37 PM
Jimmy's Avatar
Global Moderator
Default Re: (jeffb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffb16 &raquo;</TD></TR><TR><TD CLASS="quote">Cool... I'll check the main relay and tell ya'll what happens. Thanks for your help.
no problem man, let us know
Old Jun 22, 2004 | 08:20 AM
LudeyKrus's Avatar
Yup; vapor lock happened in older carb'd cars w/ low-pressure fuel systems. That is why in hotrods they would run an "icebox", which was a coffee can full of dry ice where they ran the fuel lines into it to cool off.
The problem was eliminated w/ the incorporation of high-pressure fuel systems and fuel injection.
Nassimab
30
May 27, 2016 10:08 AM
Pwnmeister
Aug 2, 2011 12:41 PM
dizzyroc88
May 19, 2006 05:32 PM
