Bogging on 92 Teg
Old Jun 20, 2004 | 04:18 AM
E-brake or Handbrake's Avatar
Default Bogging on 92 Teg
My car bogs a little when it's not fully warmed up in the morning or before a drive. I do keep it warm for a good 3 minutes before the drive if it's in the morning. 1st-2nd-3rd gears will bog when going 2-3rpms. The bogging will go away after 5 minutes into driving. Woudl a faulty o2 sensor be the cause along with other things? Suggestions would be appreciated. Thanks!
Old Jun 20, 2004 | 04:49 AM
moacsupreme's Avatar
Default Re: Bogging on 92 Teg (Inconclusive)
Mine does the same thing. When you go to pull out, it just bogs down to the point where you can have it floored and nothing. You almost come to a complete stop after pulling out. Then all of a sudden, it just goes like a bat out of hell. I've done a lot of searching, and here is what everybody has said to check.
-Spark Plugs and wires
-Distributor cap and rotor
-Oxygen sensor
-Throttle Position Sensor
-Fuel Filter
-Other problems in fuel system
-Ignition timing not set properly
There may be more, but that should be enough to get you started. If you search under "hesitation", you get quite a lot of results. Just look through them, and you'll find more information.
Ed 341
Jul 17, 2006 06:24 PM
Jorsher
May 2, 2006 05:09 PM
civictunr_ls
Feb 23, 2005 03:19 AM
coupey
Aug 19, 2004 03:13 AM
SIK IN DA HED
Nov 22, 2002 03:43 PM
