oil feed/return fittings the same for garret and turbonetics????
Old Jun 19, 2004 | 08:02 PM
Devine's Avatar
Default oil feed/return fittings the same for garret and turbonetics????
I purchased a oil feed and return line kit for a garret turbo, as it turns out i might end up purchasing a turbonetics turbo because of some complications ive ran into, my question is do they have the same flanges? anyone with positive input would be greatly appreciated.
Old Jun 21, 2004 | 01:16 PM
Devine's Avatar
Default Re: oil feed/return fittings the same for garret and turbonetics???? (Devine)
anyone
Old Jun 21, 2004 | 01:30 PM
NVturbo's Avatar
O.G. triple O.G.
Most turbines use a universal size for the inlet and also for the outlet. I used to have a Turbonetics turbine and now I have a Precision unit, and they use the same size on both, inlet and outlet, respectively. The inlet thread is 1/8"NPT and the outlet(return) flange is usually using a 1/2"NPT thread. Or you could have done what I did, buy everything seperately (6AN lines and connectors--inlet, 10AN lines and connectors--outlet). Summit Racing has just bout everything you might need....check them out.
Old Jun 21, 2004 | 06:38 PM
Devine's Avatar
Default Re: oil feed/return fittings the same for garret and turbonetics???? (NVturbo)
thank you! you sir are a gentleman and a scholar, but seriously thanks thats exactly what i was looking for.
Old Jun 22, 2004 | 09:32 PM
Flamenco-T's Avatar
Just for future references:
Anything T3 based cartridge are made by Garrett. Precision, Innovative, Turbonetics made the wheel and the housing, but the center cartridge are most likely to be garrett.
stan
projectxspeed
Apr 19, 2005 03:45 AM
oz`Vtec
Jun 9, 2004 07:26 AM
Carp
May 8, 2003 04:29 PM
Tofurky
Dec 12, 2002 03:42 PM
boosted hybrid
Nov 27, 2001 05:23 PM
