Should my charge pipes be able to hold pressure when the turbo inlet is blocked off?
Old Jun 19, 2004 | 05:36 PM
Sinner's Avatar
Default Should my charge pipes be able to hold pressure when the turbo inlet is blocked off?
I was looking for leaks and my charge pipes dont leak bad, but my intake manifold will not hold pressure. Should it?
Nick
Old Jun 20, 2004 | 10:03 AM
Bailhatch's Avatar
Default Re: Should my charge pipes be able to hold pressure when the turbo inlet is blocked off? (Sinner)
Assuming it's on the motor, you would have to block off all vac ports, idle ports, and close all the runners. so, no it won't normally.
civickid03
Apr 12, 2007 11:27 AM
champLSinteg
Nov 8, 2006 12:53 PM
luis26
May 4, 2004 11:53 AM
93H22ACX
Mar 21, 2003 09:13 PM
crxtreme27
Feb 4, 2003 08:28 PM
