b16a2 swap into 1999 ex
Old Jun 19, 2004 | 05:02 PM
scivicex99's Avatar
Default b16a2 swap into 1999 ex
i need help to know what i need to do a b16a2 swap with gsr tranny into my civic 1999 ex with a/c and p/s
will the stock motor mounts work or do i need b16 ones
thankx for the help newbe
Old Jun 19, 2004 | 05:25 PM
hatchling37's Avatar
Default Re: b16a2 swap into 1999 ex (scivicex99)
You'll need the Si (99-00) mount for the rear, and I think the A/C bracket from the Si also. You also need ECU, axles, wiring harness, Helms manual, etc.
You should also search, because there have been countless threads about "I'm swapping ___ into my ___, so what do I need?" Try the FAQ thread near the top of the EG+ forum
Old Jun 19, 2004 | 06:09 PM
Jimmy's Avatar
Global Moderator
Sounds like you also need someone that can help you seriously.
How can you do the swap if you don't know what you need.
Goodluck bro
Old Jun 20, 2004 | 07:22 PM
scivicex99's Avatar
Default Re: (Jimmy)
thanks for the info
Old Jun 20, 2004 | 08:25 PM
jumpmann23's Avatar
From: Your really lame if you dock my points, WA, 98033
it should be a pretty straight forward swap. just use the 99-00 si rear mount, driverside upper mount and ac mount and you should be gravy. also i think you will be fine on the wireing side aswell. if you get the 99-00 si wiring harness with the swap it shoudl be plug and play. good luck
tampabud
13
Feb 20, 2019 10:11 PM
LsScivic
Jul 11, 2009 12:31 PM
mrsurfermike2001
14
Apr 1, 2003 08:49 PM
98civicGSR
Mar 27, 2003 05:15 AM
kycivicboy
Sep 15, 2002 01:51 PM
