Torque Specs
Old Jun 19, 2004 | 04:52 PM
ELAMINT5's Avatar
Default Torque Specs
Does any one know where I can buy a book or look up online what the torque spec and the order I should tighten everything on my B16A1? Currently replacing the oil pan and cams and do not want to over tighten or warp anything
Old Jun 19, 2004 | 06:00 PM
Two_K Si's Avatar
Default Re: Torque Specs (ELAMINT5)
I can help you. IM me.
Old Jun 19, 2004 | 06:43 PM
im sabah's Avatar
oil pan is probably 12-14, cams i cant help you. i dont know if you can d/l a fsm for that motor because i never really researched it like that cause i dont own a honda, but ive seen several threads with links to sites that have various fsm's for download. do a search
Old Jun 20, 2004 | 08:59 AM
RCautoworks's Avatar
Default Re: Torque Specs (im sabah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by im sabah &raquo;</TD></TR><TR><TD CLASS="quote">oil pan is probably 12-14</TD></TR></TABLE>
Its 8.7 foot pounds, if you torque these to much, the oil pan will start to bend and you will leak oil. Also make sure you punch out all the nipples in the oil pan, or else they will rip the gasket.
Old Jun 20, 2004 | 01:32 PM
ELAMINT5's Avatar
Default Re: Torque Specs (90blackcrx)
is there a book for everthing?
Old Jun 20, 2004 | 03:03 PM
Yep the helms book, I think the site is like helminc.com , not to sure though.
Old Jun 21, 2004 | 03:04 PM
ELAMINT5's Avatar
that's the right site THANKS!!!
san_luis
Mar 22, 2010 10:09 AM
elchapin
Nov 27, 2009 05:55 PM
Hatch It
12
Aug 23, 2006 09:49 PM
JDubya
Jun 9, 2004 03:11 PM
prjctCIVIC
Sep 1, 2001 09:53 PM
