welding on cast iron
Old Jun 19, 2004 | 01:29 PM
KOOL-AID's Avatar
Default welding on cast iron
ok i have a question my buddy welded on a plate on an cx manifold and i thought that it was not good to weld on cast iron he did this because his making a custom turbo i told him to get a revhard manifold but whatever!!
Old Jun 20, 2004 | 05:57 PM
splinter51's Avatar
Default Re: welding on cast iron (KOOL-AID)
cant weld cast!!!!
Old Jun 20, 2004 | 06:16 PM
Evil EG's Avatar
Default Re: welding on cast iron (splinter51)
yes you can...you just need to be l337.
Old Jun 20, 2004 | 06:42 PM
Sobe_Death's Avatar
explain old 1337 one...
Old Jun 20, 2004 | 06:43 PM
sleep's Avatar
ok here we go.... even with the proper gas and wire welding on cast iron is not strong.. sure it will work but durablity is a major issue.
good luck!
Old Jun 20, 2004 | 06:46 PM
Evil EG's Avatar
Default Re: (sleep)
how do they put vbands on exhaust sides of turbo housings? Do they staple it? Ive had my turbo manifold welded when it had a crack in it and it was a cast rev hard one.
Old Jun 20, 2004 | 08:05 PM
HumanResource's Avatar
The proper way to weld cast iron is to get it at a really hot temp
Of course this is after all surface rust is removed
I've seen the adaptor plate welded str8 onto the HF manifold w/ no probs for at least a year. I'm sure if u were ON IT all the time I doubt the mess would hold up to the extended heat.
Old Jun 20, 2004 | 08:20 PM
c jackson's Avatar
threes
Default Re: welding on cast iron (HumanResource)
you have to use a torch to heat the metal till it glows. then you can weld it.
Old Jun 20, 2004 | 08:28 PM
green91's Avatar
ah a little flux wire welder should do just fine :/
s.cha
May 11, 2009 08:44 PM
igo4bmx
Dec 28, 2005 10:12 AM
gtcali
Welding / Fabrication
Aug 23, 2004 03:35 PM
BoostedB20A
Mar 16, 2003 08:59 PM
01ITR#700
Jan 11, 2003 04:38 AM
