Swaybar clearance
Old Jun 19, 2004 | 01:10 PM
boywonda's Avatar
Default Swaybar clearance
Just installed ST front and rear sway bars went on pretty easy but when I started the car I heard this horrible rattling sound look it over and the front bar is hitting against my cat (carsound 2.5)!!!! What can I do to get another 1/2 inch or so of clearance? Or is there anything at all I can do? Will this hurt anything? All feedback greatly appreciated.
Old Jun 19, 2004 | 03:09 PM
jmk2888's Avatar
Default Re: Swaybar clearance (boywonda)
I have ST Sway Bar as well with my one Piece DC 4-1 headers and R*SR Exhaust.
It rattles on my Stock Cat, the sway bar sits higher than I expected.
So I took my heat shields off my stock Cat, and now it does not rattle.
Do you have headers?
If you do it might cause your Cat to rattle too. I would put the stock Cat back and take off the heat shields.
Old Jun 19, 2004 | 03:19 PM
dogfood's Avatar
Default Re: Swaybar clearance (jmk2888)
i was having a rattle on my cat without the sway bar, take it off and don't worry about it
Old Jun 19, 2004 | 04:23 PM
boywonda's Avatar
I have dc jdm 4-1 and carsound 2.5 inlet/outlet cat
Old Jun 20, 2004 | 09:41 AM
boywonda's Avatar
Well a friend of mine suggested putting a jack under the exhaust and jacking it up which gave a little clearance (like 1cm) but enough to stop the rattling at idle now only rattles when I turn at a certain rpm
bandaidmd
Honda Civic (2001 - 2005)
Oct 27, 2007 07:56 PM
boywonda
Jun 20, 2004 07:44 PM
REVolution
Jun 2, 2004 10:31 AM
Andrea_Aunie
Sep 14, 2002 06:35 AM
Blue-Civic-Hybrid
Mar 11, 2002 02:19 PM
