Swaybar clearance
Old Jun 19, 2004 | 12:57 PM
boywonda's Avatar
Default Swaybar clearance
Just installed ST front and rear sway bars went on pretty easy but when I started the car I heard this horrible rattling sound look it over and the front bar is hitting against my cat (carsound 2.5)!!!! What can I do to get another 1/2 inch or so of clearance? Or is there anything at all I can do? Will this hurt anything? All feedback greatly appreciated.
Old Jun 19, 2004 | 03:17 PM
Starrman85's Avatar
Default Re: Swaybar clearance (boywonda)
i would wrap the bar that is touching the cat with something that can withstand a lot of heat...like maybe header wrap or something like that. just an idea.
Old Jun 19, 2004 | 04:24 PM
boywonda's Avatar
Default Re: Swaybar clearance (STARRMAN85)
Thats what I was thinking... Think im gonna give it a try. What can I get that will have a little cushion to it?
Old Jun 19, 2004 | 05:30 PM
Starrman85's Avatar
with a little cushion? only thing i can think of is the stuff you use to wrap pipes around a house, the foam stuff. but i think the heat might be too much for it. you could try using the pipe wrap stuff, then wrap the header wrap around that, and see if that works.
Old Jun 20, 2004 | 02:44 PM
boywonda's Avatar
well a good friend told me to put a jack under the exhaust and jack it up and it helped alot not sure how but it did... but didnt eliminate it completely
Old Jun 22, 2004 | 09:37 PM
DexterThEG's Avatar
he just bent it a little, out of the way
Old Jun 23, 2004 | 08:14 PM
boywonda's Avatar
Default Re: (DexterThEG)
any other ideas?
bandaidmd
Honda Civic (2001 - 2005)
Oct 27, 2007 07:56 PM
Knightmare69
May 14, 2006 04:37 PM
Knightmare69
Apr 14, 2006 07:55 PM
boywonda
Jun 20, 2004 07:44 PM
boywonda
Jun 20, 2004 09:41 AM
