Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Swaybar Clearance ?
Old Jun 19, 2004 | 12:57 PM
boywonda's Avatar
Default Swaybar Clearance ?
Just installed ST front and rear sway bars went on pretty easy but when I started the car I heard this horrible rattling sound look it over and the front bar is hitting against my cat (carsound 2.5)!!!! What can I do to get another 1/2 inch or so of clearance? Or is there anything at all I can do? Will this hurt anything? All feedback greatly appreciated.
Old Jun 19, 2004 | 02:32 PM
Crosser's Avatar
Default Re: Swaybar Clearance ? (boywonda)
Sure, get rid of it. You really don't want the ST front bar on anyway. You are better off with the stock one on front and the ST rear bar.
Old Jun 19, 2004 | 04:25 PM
boywonda's Avatar
Default Re: Swaybar Clearance ? (Crosser)
My car didnt come w/ either stock bar. So thats not a option. Definately not gonna get rid of it after paying good money for it
Old Jun 19, 2004 | 06:23 PM
boywonda's Avatar
need more help!!! Please
Old Jun 20, 2004 | 12:51 PM
Xian's Avatar
remove the cat and use a test pipe maybe?
Old Jun 20, 2004 | 02:40 PM
boywonda's Avatar
Default Re: Swaybar Clearance ? (Xian)
Dont want to really do that considering I just paid $150 bucks for the cat and the flange and the gasket. Is this hurting anything? (besides my ears)
Old Jun 20, 2004 | 05:14 PM
Chris's Avatar
When I installed them on my 98 GSR (back in 98, I am surprised they still have this issue) I had this problem.
They sent me at no charge, shorter endlinks. You can cut the "spacer tube" shorter and get a shorter bolt and there you go. Lowering the ends closer to the LCA will tilt up the middle section and move it away from the O2.
this will fix your issue.
Old Jun 20, 2004 | 07:44 PM
boywonda's Avatar
Default Re: Swaybar Clearance ? (Chris)
Thanks Chris, but since I have a civic coupe w/o stock front sway the bar goes under the cat. (yeah I was kinda weary about that) so I cant go up any farther and if I go down(which I thought about) I would be uneasy about clearance from objects in the road.
bandaidmd
Honda Civic (2001 - 2005)
Oct 27, 2007 07:56 PM
pearlteg
Dec 27, 2004 02:53 PM
boywonda
Jun 20, 2004 09:41 AM
REVolution
Jun 2, 2004 10:31 AM
Blue-Civic-Hybrid
Mar 11, 2002 02:19 PM
